Help---Ecu trouble code 8 TDC sensor
Old Mar 9, 2005 | 09:18 PM
GOTTI's Avatar
OEM Parts Specialist
Default Help---Ecu trouble code 8 TDC sensor
Still throwing this code (#8 Top Dead Center sensor)after new obd1 distibutor install reset ecu already) ....can anyone help?
Old Mar 9, 2005 | 09:24 PM
warpd's Avatar
Could be your timing is really off
Old Mar 9, 2005 | 09:48 PM
mtber's Avatar
By "new" do you meen a napa rebuilt distributor etc ?
Napa, Discount, Distributor king distributors sometimes can be defective altho they are "new".
Old Mar 10, 2005 | 04:22 AM
GOTTI's Avatar
Brand new OEM Honda/Acura distributor housing. I already had a brand new coil and ignitor.
I was told the sensor was in the housing. no?
Old Mar 10, 2005 | 01:32 PM
mtber's Avatar
The sensor is in the housing...
Old Mar 15, 2005 | 05:24 AM
GOTTI's Avatar
i am open for some offers on how to get rid of this code from my car. Its the only problem i have right now. i just want it to run right. Let me know if anyone is up to help Diagnose...
Old Mar 9, 2008 | 05:34 PM
tenpoundboost's Avatar
Default same problem
92 prelude f22b block h-23 heads, no v-tec.... have checked and reched timing... repositoined the cams and i know everythin is right as far as being tdc and having cams lined up with the dis on the n0 1 firing pos. checked all currents resistance and ohm levels....changed dis 3 times and tried 3 different e c u's even had 1 chipped out to fit my specs.... still throwing an 8 code...
Old Sep 10, 2009 | 11:50 AM
JERZYFINEST360's Avatar
MR ROMPE TOTO
Default tdc
am having the same problem got new distributor still throwing code 8 n 4 have gone threw alli could and still nuttin am gonna have neal sutton take a look will post what ever i find out it sucks i got no vetc n cant go past 7k
SILVIA-S14
Toyota/Lexus Tech
May 20, 2004 10:59 AM
40ozCasualty
Jan 23, 2004 07:04 PM
GearGrinder
Dec 24, 2003 06:24 PM
MSP Chris
Apr 4, 2003 07:41 PM
gotvtec20
Aug 14, 2002 01:00 PM
