TDC sensor error...
91' prelude ECU's spitting out a TDC sensor error, Does anyone know where the TDC sensor is located, or anything about the cause of this error ect.? Also, Does anyone know how to jump the ECU? I read something about a molex connector with a brown and a black wire, and you had to create a circuit between them, But I can't seem to find this molex connector in the center console, as was the stated location.
the tdc sensor is located in the distributer. could be a wire problem or bad dist. what are you trying to do by jumping this connector. you pull the codes by reading the flashing LED on the ecm.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
