what ecu to use?
what ecu to use?
im swapping a d16y8 sohc vtec motor into my 94 dx hatch. i need to know what ecu to use to make this work. and will the obdII harness plug into my obdI cuz i heard it can be done. thanx all.
A obd2 civic wiring harness will not plug into a obd1 94 civic.
You will need a obd1 p28 to run the sohc vtec d16y8 in your 94 civic.
if you're using an OBD 1 computer you don't need to use the OBD 1 - OBD 2 harness...
Use the distibutor that corresponds to the ECU you want to use. I personally am tired of answering this dumbass question over and over. USE THE SEARCH AND STOP REPOSTING!!!
https://www.tamparacing.com/forums/s...d.php?t=213428
Shut yo ass up nugguh..
ReginaVagina
ReginaVagina
