LsVtec Breaking up in Vtec
I had a feeling it was the ecu/ vtec engagement problem. I had a pr3 but it ran like shit with it plugged in, it like retarted the timing big time compared to the pr4. I got another question. When wiring the pr3, Theres a green sensor off the back of the block, can i use that for the knock sensor? and does anyone have a link to where to wire everything else? Thanks -Ben
Ok this might sound stupid but I thought that there was a oil press sensor on the vtec solenoids? I have a 01' Gsr head, do they not use the oil press sensor? If so, what could I do to bypass this because a pr3 will not kick vtec in if it sees no oil press. Someone ever had this problem? Let me know how to get around it. thanks -Ben
I didnt think VTEC solenoids would differ between eachother, but if Im understanding this right, why dont you just get an OBD-0 vtec solenoid? I would think that EVERYTHING should be converted to obd0 obviously...
I got the pr3, now I just need to figure out how I'm going to get by the vtec oil press. on the ecu, I think im just going to tap into my oil press. sensor on the block. Let me know your input. Thanks -Ben
hey ben whats up long time no see. You got the hatch back from jason? still workin on ls/vtec I see. nice. I tryed callin ya a little while ago you never called back. ahwell. good luck bro.
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
