LsVtec Breaking up in Vtec
Old Feb 7, 2005 | 06:10 PM
Janky99's Avatar
Honda Guru
Default LsVtec Breaking up in Vtec
Ok heres the breakdown.. This is my setup and the problems im having:
B18A Block
Jdm ITR Pistons
Shotpeened Ls rods
Micropolished crank
Gsr oil pump
Gsr water pump
arp rod bolts
01 Gsr Cyl. Head
Pr4 Ecu
Summit Rpm activated switch
Apexi AFC
Ok heres the problem.
When I take the car into Vtec, which is set at 4400.. it feels like it has like a hold on it then it like pulls like crazy at about 6K. So basically its breaking up or just completly loosing the power between 4400 and 6K. but in every gear its the same rpms. even when I take it into vtec slow it like doesnt open up clearly like it should, its sounds all crackly and you can feel it in the car. I think its the RPM switch but i didnt think it would be a problem since i have the afc and i have it richened out through vtec. If anyone has had the same problem let me know of if anyone knows what it could be let me know. thanks alot. -Ben
Old Feb 7, 2005 | 06:29 PM
60-1EK's Avatar
Engineer at the source
Its your management. How are you adjusting timing? Get serious. UD is inexpensive and works well if you are on a budget.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Feb 7, 2005 | 06:32 PM
BitbyStreetRacin's Avatar
once your bit, your done.
Why dont you just get a pr3 or pw0 ECU, or something along the lines of a DOHC VTEC ecu?
Old Feb 7, 2005 | 07:19 PM
uncle bens wildrice's Avatar
i heard vtech
ben pm smart man and get his pr3
Old Feb 7, 2005 | 07:29 PM
2ndGenT3g's Avatar
get a different ecu first like a chipped p28. then if your runnin stock head, set the vtec to kick in at about 4800-52000 just my 2 cent. plus your using the gsr head so could be different.
||=|| ((O)) ||\\ || |D) //-\\
DB2-SOLD!
Dc5 Type-S-SOLD!
97 civic 4dr-SOLD!
05 civic 4dr EX SE-SOLD!
08 Acura TSX_ 6mt
Old Feb 7, 2005 | 07:33 PM
Jaso0on's Avatar
Is now ballin!
I think its the fact that hes still using stock fuel injectors, Ben if u get some prelude 290cc injectors at least, and a real obd0 vtec ecu, im sure the problem will be solved...
-Jason
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
Old Feb 7, 2005 | 07:35 PM
KJ's Avatar
KJ
bored at work
A vtec ECU will solve your problems.
Old Feb 8, 2005 | 04:37 AM
99B16Si's Avatar
sell the afc and use the money for uberdata or crome tuning. youll break even money-wise and your car will run 20 times better. and a pr4 is a non-vtec ecu. unless u have vtec hardware added to the ecu i dont see how vtec is even gonna work properly
Old Feb 8, 2005 | 08:06 AM
60-1EK's Avatar
Agreed. He is running the vtec off a rpm switch.
JESUS SAVES
9.69@151 Street Car
JKOBD
