Piston Rings Fried?
My car cought on Fire!
on
Piston Rings Fried?
How can you tell when your piston rings are fried.....
does your car start feelin different when you drive, or do you just
blow out smoke?
blow out smoke?
theres different cases- usually if you blow out the rings on one cylinder, you'll feel a miss or a lack of power. with some motors, if you run it low on oil, rings can actually bore out your block just enough to defeat the purpose of the oil control ring, causing you to blow smoke (thats usually older motors). Check the balance of power from cylinder to cylinder to try to isolate your problem. whats your concern anyways? sorry im drunken babbling on tr bufhidoahyrbfybvuytbgknFIgrftleyinhjlkngbguyhguit5 h.
Quote; Stan Marsh from "Southpark", concerning his friends Cartman, Kyle, and Kenny obsessing over facebook:
"You guys are retarded, I'm playing XBOX."
on
well, the thing is. I am runnin lean right now, Till Wednesday when i get my Custom Rail that way i can fit my RC 310's in there!....*I am turbo'd by the way*.. So since i've been runnin lean. anyhow..
I knw when your're runnin lean the combustion go's up=wich that mean Temp go's up/./ so after I've been driving for about 30 min in the hot sun, i start smokin outta of the exausht on idle!....(dont knw when i'am driving)
Its kinda bluesh, but it reall doesnt smell like oil, its also white sometimes...
so i am thinkin its the combustion temp going up real high,
due to not enough fuel and to much AIR.....
?>?????????????????any INFO????
you may have some kind of blow bye. you need to do a comprerssion test and leakdown test just to be sure, is it on deceleration as well?
if the rings go bad enough, or the lands melt, you will be smoking from the valve cover breather like a bitch, trust me
on
oh really... WEEeeeeeeeeeuuufff
thanks.. lol
nope, I dont have any smoke commin out of the Valve cover..
car runs great..
It must be a blow by or something..
After i put that new rail in there
Crossin my fingers
With tunnin , it should all be straight.....
[VIN Diesel voice] now me and the mad scientist are going to have to rip apart the block to replace the piston rings you fried!!!!! [end Vin Diesel voice]
You can find me at the Track!
KJ built
ALPHA TUNED
Induction Performance 727.505.1423
* Engine Management Tuning, Track Setup, Consultation, Turbo Sales, Parts Sales (WorldWide)
ONLY SHOP IN TAMPA THAT TREATS YOUR CAR AS THEIR OWN
KJ built
ALPHA TUNED
speaking of that....i have to do that to my car...anyone want to help me just rebuild the entire engine?
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
