vtec problems
Old Dec 29, 2003 | 04:42 AM
cheesy's Avatar
Back on the road again...
Default vtec problems
i was gonna buy a civic from this guy who said it had a bad cylenoid for the vtec so the vtec wasnt working. i didnt buy it i got a crx with a b17a1. lately my vtec either hops around like its skipping a beat or doesnt even hit. i know the car has a sticky valve but i dont know if that has anything to do with the vtec not acting right. i want to know if it is this cylenoid? and if it is or if its something else please help me. i need my vtec for the track event.
Old Dec 29, 2003 | 05:31 AM
civicracer901's Avatar
B16ACRX
*check oil level
*check your filters on your vtec (there are two) one on top and one on the side) 3 10mm bolts on top by the solinoid.
*check if your throwing any codes on the ecu located on the passenger side firewall below the glove box.
*you can test your VTS by adding power to it straight from the battery. just a wire/gound to the Sol. plug. should here a click sound. Car on. It should either stall or idle really low if its working.
*I would check the spark plugs to.
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Old Dec 29, 2003 | 07:52 AM
Sharpview's Avatar
hyperbola
is this the same for a b18c1 motor? i've never heard of these filters, might need to change mine . . .thanx -mike
Old Dec 30, 2003 | 11:52 PM
fresh&clean's Avatar
I love Lamp
Hey its probably your vtec solenoid they arent that expensive like 50 dollars.
