best swap
Old Aug 30, 2004 | 04:47 AM
  #51 (permalink)
Bill's Avatar
Livin' in Seattle
Originally posted by RyanCivic2000
Has any of the information you've ever read explained why two cams would be better than one? Why would you want two cams to do the same thing one cam can do? I'll give you a few concepts to get you started.
-SOHC motors have less rotational mass and less frictional losses.
-Vavle angles allow for more radical camshaft profiles.
-The F Series in particular has higher and superior port angles to the B and H Series.
-Spark plug placement is better.
-Less parts and cheaper parts.
-SOHC engine is much lighter overall.
The only advantage to a DOHC is the ability to tune in overlap with seperate cam gears, which if you have the correct camshaft grind to begin with in the SOHC, you don't need to worry about it.
The advantages of the DOHC engine over that of the SOHC lie directly in the placement of the cams. Due to cam position, the DOHC design allows the spark plug to be placed directly in the middle of the combustion chamber (optimal regardless of what you may say above). Also, due to the cams laying directly over the valve train, valve duration can be minimized due to better float prevention and thus enabling a higher rev limit (a large reason you see DOHC not SOHC in F1 motors).
Now as far as your B-series vs. D-series debate goes, it all depends on how far the person wants to go in messing with the engine. Myself, I went with a B18C5, not because of the "hype" as you like to put it, but due to the completeness of the package. I was able to get a transmission with great gearing, stock LSD, more displacement over a d-series, internal and external oil cooling, strong internals (well as strong as OEM cast can be considered), moderately aggressive cam grinds, and a great head. All that was required was for me to bolt it in and go hit some road courses. With a D-series motor, while I don't doubt I could make the same power, it would require quite a bit more time and effort. To each his own I suppose.
Old Aug 30, 2004 | 05:26 PM
  #52 (permalink)
RyanCivic2000's Avatar
Fuck the DOHC
Bill, in regards to sparkplug placement, you are wrong. The SOHC placement is superior and allows for a more efficient combustion. There is a significant power loss with a centralized plug (especially with domed pistons) and the charge burn can be hindered upon combustion.
With the right valve springs, valvefloat will hardly be an issue. I would be more concerned with the stroke and piston speeds.
BTW, I didn't bring up the F1 car example, matraca112 did.
-00 Civic EX Coupe BUILT D16Y8, Precision SC50, 12.80@105.8 14psi
-00 Chevrolet S10 LS 4.3L V6 Gas Guzzler
http://www.Sohchonda.com
Honda SOHC & D Series Resource
Old Aug 30, 2004 | 06:54 PM
  #53 (permalink)
matraca112's Avatar
hey i am just here to see what is the best engine to go with what i am looking for in my car.and the more everyone brings things up the more everyone can learn. but i will say this both DOHC and SOHC must have there pros ands cons. so it just ends up being a personal pick.
[SIGPIC][SIGPIC][SIGPIC][SIGPIC]
Old Sep 1, 2004 | 09:40 AM
  #54 (permalink)
Bill's Avatar
Livin' in Seattle
Umm...again I disagree.
While valvefloat can be addressed by stiffer springs, this in turn increases frictional losses as well as increasing valve-train wear. DOHC offers the better solution.
As far as the plug placement is concerned, there's a reason that the plug is angled and not centered, it's due to a cam sitting directly overtop. While I'm sure placement is ideal for the situation, it is not overall ideal. Regarding higher piston domes, yes, they do present more impedence for the flame front than that of lower domed pistons. However, this can be countered by advancing the timing. Couple this with the benefit of centrally located plugs (enable less advance) and you have a decent workaround.
But don't take my word for it. Below is the result of a quick google search. Please find me some information supporting your side, preferably more than one or two sources from BBS posts.
Honda press release on NSX
The spark plug is centrally located for optimum flame propagation and features a platinum tip for improved durability and longer service life.
http://www.honda.ca/AcuraEng/Models/NSX/Benefits
Article on Ford's 3-valve V8 for the 2005 Mustang
The spark plug is now centrally located, which gives you a symmetric flame front, thereby greatly reducing the possibility of detonation.
http://www.musclemustangfastfords.co...403mm_mustweb/
Article on Cosworth F1 Engine Development in the 60's (A revolutionary design...central plug)
These four valves would probably have given sufficient gas flow if they had been set vertically. However, mainly to leave room for the spark plug boss to be located centrally between the valves and provide smoother curves in the gas passages to and from the valves, the pairs of inlet and exhaust valves were inclined at 20 deg towards the opposite sides of the engine.
http://www.avant.co.nz/lotus/dfv.htm
Article touting the gains of a DOHC engine over the "Hemi".
The chamber of choice of the Japanese “super” bikes (the Kawasaki Ninja, the Honda Hurricane, the Yamaha FZR, etc.) and Indy and Formula 1 engines, the pent-roof permits a flat (or even concave) piston, a cylinder head that is only slightly domed, and a centrally placed spark plug. The effect is that the fuel and air mix are ignited rapidly because the mix is concentrated tightly around the plug. That allows higher compression ratios to be used with less fear of dreaded detonation—the charge quickly burns before the detonation
http://www.schubeckracing.com/Anewge...aceengine.html
Brief article on the DOHC Vtec Engine
The quick-burn, pent-roof, high-swirl chamber with a centrally located spark plug is icing on the cake!
http://www.hotrod.com/techarticles/engine/113_0307_vtec
Brief article on GM concept engine (2001)
"Using three valves-two inlets and one exhaust-gives you more room in the combustion chamber for optimal positioning of the injector and the spark plug, vertical and nearly central in the chamber," Indra said.
http://www.autospeed.com/cms/A_1193/article.html
Brief article engine design
DOHC designs have another advantage when coupled with four-valve cylinder heads. It allows the spark plug to be placed smack in the center of the combustion chamber, which promotes efficient combustion and reduces the engine's taste for high octane fuel. With an SOHC engine, the camshaft is usually in the middle of the head, precluding this optimal plug location.
http://www.jag-lovers.org/e-type/perf.html
Article on an interesting engine design
The design of the CSRV, which at first glance resembles an OHC cylinder head, allows for the central placement of the spark plug in the bore. By varying the spark plug location when referenced to the bore centerline, the most desirable position is in the center. This will allow the cylinder pressure build in the minimum amount of crank rotational degrees past TDC.
http://www.coatesengine.com/look_mom_no_camshaft.html
Article on good motorcylce engine basic design concepts
A centrally-located spark plug causes combustion's flame to reach deeper into the remote edges of the cylinder, turning more BTU into useful work, and eliminating the end-gases that often initiate detonation.
http://www.motorcycleproject.com/mot...t/secrets.html
Old Sep 7, 2004 | 08:08 AM
  #55 (permalink)
Fuck the DOHC
Bill, most of your examples and links there are for mass productions lines (Ford, NSX, GM). These are not 9 second drag cars, and they are not manufactured to run upwards of 14:1 compression. My information comes from Bisimoto who has built many drag cars like this. You will not find his information published on any website you find on Google.
