ECU question: honda tech's enjoy this one!!!
Old Jun 4, 2004 | 12:24 PM
  #21 (permalink)
TSX24L's Avatar
Is this a purple crx?
Old Jun 4, 2004 | 12:25 PM
  #22 (permalink)
TSX24L's Avatar
Marks old car?
Old Jun 4, 2004 | 12:40 PM
  #23 (permalink)
Jaso0on's Avatar
Is now ballin!
no its the one in my sig.. lol not marks old car..
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
Old Jun 4, 2004 | 01:07 PM
  #24 (permalink)
rangcrx's Avatar
engine building &best
thats the joys of owning a swapped honda o make it perfect the way you wish like said buy keith you might want to just sell it low and get out of the imports if not willing to spend thay will eat up all your money b4 you no it and it still will not be perfect
i love AUTOZONE
Old Jun 4, 2004 | 03:18 PM
  #25 (permalink)
juiced2ndgenteg's Avatar
when running a pwo or a pr3, NO o2 sensors are better than just running 1. 2 o2 sensors is how it was from the factory. the o2 sensor problem will only cause a problem at less than 25% throttle as the ecu is in open loop mode and the o2 sensors create the fuel map. after 25% throttle the ecu goes into closed loop mode(i.e. runs on the base map). when running no o2 sensors the pr3/pw0 will run in closed loop all the time. If your car has sputtering problems throughout the rpm range at full throttle its not an o2 problem.
Old Jun 4, 2004 | 03:29 PM
  #26 (permalink)
vertigo_16201's Avatar
Doesnt create new maps, it modifies the current map from -30% to +30%. And open loop/closed loop is alot more complex than just tps, and the crossover point is over 25%. ECU takes lots of info into consideration. It is true that it wouldnt affect WOT however.
Old Jun 4, 2004 | 07:57 PM
  #27 (permalink)
Jaso0on's Avatar
Is now ballin!
ok we did the timing today.. it sputters a little bit until like 3k rpms!!!
Old Jun 4, 2004 | 11:04 PM
  #28 (permalink)
Jaso0on's Avatar
Is now ballin!
would me needing a new dist. rotor button have anything to do with it acting up like this??
Old Jun 7, 2004 | 08:45 AM
  #29 (permalink)
over 25%, I don't think so..... IMO
Old Jun 7, 2004 | 10:05 AM
  #30 (permalink)
Jaso0on's Avatar
Is now ballin!
ill try it anyways..
