serious hesitation
Old May 13, 2004 | 04:16 AM
Old Renegade's Avatar
Cool Runnings
Default serious hesitation
i have had this problem before and changed my o2 sensor then my coil ignighter, was ok for a while now its happening again, so i changed my o2 sensor once more and still is happening and even worse. the car is a first gen b-16a what car do i get the ignighter for i think its for a 88-91civic but not too sure. this will solve the hesitation problem right? or am i going in the wrong direction to get this fixed. by the way i have an aftermarket header so i am running one o2 sensor.
Old May 13, 2004 | 11:37 AM
skunk2eg's Avatar
I miss my cx motor
what kinda hesitation? cpuld it have to do with the ignition timing or the timing belt?
***!! will pay $$$ for: Black GSR leather front seats and a 92-95 hatch black cargo cover !!***
Old May 14, 2004 | 04:10 AM
Cool Runnings
no the belt and timing is fine it runs fine for a few after i start it up then it sputters almost to popping sound with terrible hesitation like some real power loss.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old May 14, 2004 | 06:07 PM
na200whp's Avatar
Powered by BOOST
check your plugs .could be fouled.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old May 15, 2004 | 06:25 AM
KJ's Avatar
KJ
bored at work
Convert to obd1 so you don't have to deal with the shitty obd0 distributors and electronics.
Old May 15, 2004 | 08:17 AM
Cool Runnings
i plan to and when i am ready to do that will let you know so you could do the conversion for me. will check plugs but think they are fine they are the ngk bkre-11.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Old May 15, 2004 | 02:04 PM
Riptide101's Avatar
I would check you distributor cap. I had the same problems 3 months ago.
Old May 15, 2004 | 02:17 PM
TSX24L's Avatar
Iam kinda confused, does the poping sound happen at idle or accel or delcel? Like does it seem like there is to much fuel?
Old May 16, 2004 | 04:28 AM
Cool Runnings
distridutor cap is fine no cracks or anything to cause problems points are and was cleaned, popping happens only at acceleration.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Old May 16, 2004 | 06:32 AM
Cool Runnings
changed the ignighter and still is doing the same thing i will wait till the car is cooled down then swap out the o2 sensor and see if this will finally do the trick. riptide101 did you get your problem solved and if you did what did you do to correct the problem.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
