GSR Swap ?
Old Jan 25, 2004 | 09:19 AM
  #21 (permalink)
Spyderxl98z24's Avatar
Honda Tech/ Local AssHole
Originally posted by `92CXhatch
ok here is my thoughts on skimming over this thread... P28=shitty... good computer... but i always love my knock sensor... dont look at it as a pain in the ass... she, the knock sensor, is your friend ... LS/Vtec=BIG thumbs down... if you need a reason why please feel free to search... as for the butterfly problem... one of two things can be done... pull the vacum line off the solinoid (sp?) and then they will stay open... or replace the manifold... also just so you know i would run a p72 or a p30 both have knock sensors...
-Keith
p.s. your welcome buddy...
ok dumb question, why do you want a knock sensor and if I have a P28 can a p72 ECM plug and play in the stock harness or does it require some rewireing ? most people run the P28 just because its a so diverese ECM ?
Old Jan 25, 2004 | 04:42 PM
  #22 (permalink)
UnderPSI's Avatar
The knock sensor is a very good sensor to have. It is basicly a microphone for the ecm to listen for detonation, or knock, and depending on the severity of it, retard the ignition timing accordingly to prevent engine damage. P28 and P72 have the same connections. The p72 is desirable because it is fairly easy to get, has vtec, and is easily chipped to run the b series vtec motors. You can get a p28 cheaper than a p72 in most cases.
Old Jan 25, 2004 | 04:49 PM
  #23 (permalink)
StricKlyMT's Avatar
aka civicke96
its probably already been established but obd1 is the way to go
"STRICKLY MT" Shop open for business
Tuning available for S300 and Kpro
727-510-6301 Tristan
11.99@116 All Motor K24 Civic Eg6 on Drag Radials
MattBuilt
Old Jan 25, 2004 | 06:16 PM
  #24 (permalink)
well what if you have a P28 will it work or is it just a smart idea to plug and play a P72 and wire a knock sensor ?
Old Jan 25, 2004 | 07:03 PM
  #25 (permalink)
chinogsr1's Avatar
-Keith
right now i have an p06 chipped by kenji..the ecu is great off the line but i'm having problem with my secondary butterfly..i was gonna to get an skunk2 IM...since you say pull the vaccum line off the solinoid...will that effect anything by leaven the vaccum line off...
Old Jan 25, 2004 | 07:19 PM
  #26 (permalink)
UnderPSI's Avatar
The secondaries will stay open by default unless vacuum is suplied to the diaphram. If you remove the vacuume line from the diphram, just plug it up so you don't have a vacuum leak. When the rpm's reach 5750, the ecm turns off the iab solenoid and no longer supplies vacuum to the diaphram causing it to open. When the secondaries are closed, (vacuum suplied to diaphram), the intake path is longer and more narrow and aids in the production of more torque at lower rpms (below 5750). If you leave them open all the time, you may feel a slight decrease in power at lower rpms or a bog after vtec cross over. If I leave mine open all the time it bogs around 5000 to 5500 and as soon as it hits 6000 it takes off again. Although mine is a b16 block, the b18 may react different.
Old Jan 25, 2004 | 07:22 PM
  #27 (permalink)
problem solved with an AM intake manny !
Old Jan 26, 2004 | 01:26 PM
  #29 (permalink)
chinogsr1's Avatar
thanks for the infor..do you have a pic. diagram showing all these parts located on the b18...
Old Jan 26, 2004 | 05:25 PM
  #30 (permalink)
na200whp's Avatar
Powered by BOOST
under psi is my HERO!!!!
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
