Why Hondata?
i know very little about the hondata system so if i come of as dumb i appologize. Is hondata a good idea for a single cam engine, or does it run better on the dual cams?
CrApTaStIc!
TR "Old Skool EF" Member #213
CrApTaStIc!
also to what extent can you modify the engine before it would benefit to get the Hondata system.. also i have a NX Wet Nitrous system.. as far as i have been told the hondata is only compatible with the Dry systems is this true?
Originally posted by qitstrn
Is hondata the best?
Originally posted by Vapor
The Progress/Vortech Civic Si is the fastest Honda in the world at 204mph. Erik's Racing was the first all motor car in the 9's - and it too runs Hondata.
I dont think I'd choose anything but hondata for anything i'd ever want to do...
I dont feel like a sig today.
Originally posted by Slash
These speak for themselves.
Guest
Posts: n/a
Originally posted by low00lude
whats it cost to tune the system
Call the number in my sig for pricing information.
Also, why not read www.hondata.com a little bit, it has testimonials and such from real companies that use Hondata, real professionals, and real racers.
i had one of the 1st hondata systems, def one of the 1st in the area (after rocky).
immediately it solved all my woes of idling and fueling my high comp cammed sc Ls. i remember my heart pounding as i approached 7k, hoping it would not hit fuel cut-off, as all the 'rechippers' of the time told me it would. i made 8400 before up shifting so as not to hit the 'stock' hondata red line at 8500. the only problem i ever had was when i knocked the plug loose to the interface box and was limited to 4k for all of the 2 minutes it took me to figure out the trbl.
at the time there were only 2 systems for honda that did not require massive wiring, new harnesses or days of labor and tuning. i have met doug from hondata, i have talked to derek many times, and many people have bought hondata systems after hearing my stories on it. they even supplied me a base map to run my blower off of, and it didn't take any bandaids to do it all. its such a simple system, and it does 4 times now what it did then. now there are other systems out on the market, and they do have thier pluses and minuses. but i would still rather use a honda ecu on my honda, and look forward to the next wave of cracks for the TSX and Element K24s.
Eat a live toad every morning, and that will be the worst thing to happen every day.
