turbo or type R?
ls/vtec can be turbo'ed all day long as long as u tune it right. just make sure u calculate the compression ur gonna have. id try to get it somewhere between 9.5 and 10:1 and u can run 7.5 to 8 psi on it all day long. type r valvetrain can handle 8 psi stock. u can probably make around 250 on it with tuning and stuff. just be sure u watch that a/f ratio and id tune a street boost at like 5 psi so theres less stress on the motor and run like 9 on race gas at the track. just ditch the auto tranny cuz it'll break real fast with 250hp. like they were sayin tho if money isnt an issue than just build a sick motor and u wont have to worry about anything breaking. the formula for turbo honda's has been laid out a thousand times over. im sure u can run consistent 12s without sleeving the ls tho.
valvetrain has a lot to do with boost because at certain levels the valves will float and eventually break cuz the valvesprings can't handle it. definetly get stainless steel valvesprings and valves if u wanna run any kind of big boost.
Guest
Posts: n/a
Pistons are around 500 bucks.
Rods are 300-800 bucks depends on brand.
See www.hondata.com for prices... there are a couple other things you have to get to run Hondata on an obd2 car. Tuning is $350 from SS.
PS. Valves float from high RPM not boost.
Originally posted by Rdline1
ok well then go get some pistons and rods and run 17 lbs on an ls/vtec and we'll see how long the valvetrain lasts.
Guest
Posts: n/a
PSI has nothing to do with valves, the valvetrain, or anything.
17psi will run fine with stock valvetrain. It will not damage anything.
