LT1 help needed
Old Jun 24, 2009 | 11:51 AM
  #21 (permalink)
B4C's Avatar
B4C
Track Star
I am just assuming we can take the throwout bearing off. Or you can use the whole pressure plate, but it is the stock LT1 plate. Nothing wrong with it at all.
Keith
'94 Camaro B4C
Old Jun 30, 2009 | 12:57 AM
  #22 (permalink)
purplez28's Avatar
real men rock purple ;)
thanks b4c for the pressure plate and throwout bearing... and much appreciated
so for on the put together ive busted two bolts holding the pressure plate on its says bolt down to 52 lbs i put it on 50 and still managed to fuck them up.... looks like its guna have to get drilled out what a pain in my dick
Old Jun 30, 2009 | 10:30 AM
  #23 (permalink)
Z28ricer's Avatar
Doesnt see what you did
Thats because you fucked up your research on finding the correct info for torque on the bolts.
The correct spec is :
15 ft. lbs. plus 30°
R.I.P. Tim
RB $200
LS1 $250
Old Jun 30, 2009 | 12:38 PM
  #24 (permalink)
purplez28's Avatar
im guna have to sell my car and get a honda the way im going lol....
edit- i tightened it down to the ls1 6 speed torque numbers in the haynes manual.
Old Jun 30, 2009 | 01:31 PM
  #25 (permalink)
Z28ricer's Avatar
Yeah LS1 pressure plates are stamped steel, the LT1 plates are cast aluminum..
R.I.P. Tim
RB $200
LS1 $250
Old Jul 17, 2009 | 08:15 PM
  #26 (permalink)
purplez28's Avatar
i admit defeat , i have no clue on how to get this fork over the bearing.....
Old Jul 19, 2009 | 04:06 PM
  #27 (permalink)
Z28ricer's Avatar
The fork doesnt go on the bearing until everything is all bolted up except for the slave cylinder, leave the little aluminum chunk off the bellhousing where the slave goes also, then you slide the fork onto the bearing and it will lock in on the T stud.
R.I.P. Tim
RB $200
LS1 $250
Old Jul 20, 2009 | 10:06 AM
  #28 (permalink)
B4C's Avatar
B4C
Track Star
It didn't make sense to me either. Here is another description.
T56 Clutch Install Notes
Keith
'94 Camaro B4C
Old Jul 25, 2009 | 04:39 PM
  #29 (permalink)
purplez28's Avatar
yeah my bad fellas i finally got it a few days ago now, my clutch has no pressure until about 1/4 of the way down so now im replacing the master cylinder and slave.. so il let you know
Old Aug 7, 2009 | 05:15 PM
  #30 (permalink)
B4C's Avatar
B4C
Track Star
Did you get it workin?
Keith
'94 Camaro B4C
