LT1 help needed
center drive as in the input shaft? the piece that looked like a long gear that goes into the back of the block?
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
can you get some pics ?
Was the bolt loose on the T stud that holds the fork to the front of the transmission.
R.I.P. Tim
RB $200
LS1 $250
RB $200
LS1 $250
See the gouge around the outside edge of the clutch plate ? Thats from what I was describing to you, the bolt that holds the T-stud on, where the fork pivots backed out, allowing the clutch fork to get closer and closer to the pressure plate, eventually when you push the clutch pedal the fork will hit the plate, im guessing maybe you took it really far and it was against the clutch plate already and thats what let you get enough force to bend the lip to the throwout bearing.
Usually the throwout bearing isnt available seperately for the LT1's T56 setup, you are best off going to see tampa clutch supply, tell them you want the LT4 corvette plate and a dual friction disc, the whole setup will be affordable and do well for power handling.
R.I.P. Tim
RB $200
LS1 $250
RB $200
LS1 $250
I have my old pressure plate from when I changed it out and you are welcome to throwout bearing if you want. It only had 42K mi on it.
Keith
'94 Camaro B4C
Keith
'94 Camaro B4C
