S10 V6 Swapping To Ls1
Old Aug 28, 2008 | 04:35 PM
  #21 (permalink)
GRez's Avatar
ls1tech.com is the only site you need.
I would reccomend doing the lq4 or 9 stock crank and some good rods and pistons . and a 300 shot.
Old Aug 28, 2008 | 07:39 PM
  #22 (permalink)
Stealth Mode's Avatar
Still CREEPIN
Originally Posted by myltwon
do lt1 swap!
+1, or an lt4. in my opinion ls= tin can. personally i dont like aluminum engines, thats me. alot of ppl will disagree, but wen it comes to engines i like iron. go with an lt swap.
TurboRAM Member #5
24psi & Stable
GET SOME
Old Aug 29, 2008 | 07:40 AM
  #23 (permalink)
GRez's Avatar
You can build iron block lsx engines, and they are Wayyyyy cheap. you can pick up the lq block (iron truck lsx blocks for under $800 if you look)
Old Aug 29, 2008 | 10:13 AM
  #24 (permalink)
HybridSS's Avatar
I have fuzzy eyebrows
LS1 without a doubt! Aluminum is the way to go. 100 lbs difference from the iron LQ4/LQ9 and the LS1 or LS2 and other iron block motors.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old Aug 29, 2008 | 01:41 PM
  #25 (permalink)
GRez's Avatar
But you cant pick up an alum block too cheap.......no doubt they are lighter, but I think the $$$ saved would make it worth the extra weight.
Old Sep 5, 2008 | 06:23 AM
  #26 (permalink)
Still CREEPIN
lt4, bore it out to a 383, and then keep it stock "lookin". stock intake, ported, stock heads, ported and worked etc etc....
that will be a badass, and fun lil truck. gl man
TurboRAM Member #5
24psi & Stable
GET SOME
Old Sep 30, 2008 | 09:23 AM
  #27 (permalink)
HybridSS's Avatar
Originally Posted by HybridSS
Stay away from LHT. They are crooks!
Just to clarify....I am speaking specifically of LEE the original owner of LHT who does the S-10 swap and harnesses and fabrication/mod of custom V8 cars.
I am not talking about the guy also under the name LHT who does the honda turbo fab stuff.
Old Oct 2, 2008 | 02:33 AM
  #28 (permalink)
cpwire's Avatar
umm... I do the harnessess for the V8 swaps, and I am not associated with Lee at all.
How long ago did you deal with him?
Old Oct 2, 2008 | 10:47 AM
  #29 (permalink)
HybridSS's Avatar
Is your name Lee?
Old Oct 3, 2008 | 02:08 AM
  #30 (permalink)
cpwire's Avatar
Nope. Thank god.
