03 corvette tire pressure monitors
Old Oct 3, 2008 | 03:43 AM
2klara's Avatar
Roadkill Vacuum
Default 03 corvette tire pressure monitors
Is there a problem running a wheel with no tire pressure monitors? I have heard that it would put the car into "limp" mode. What problems will I run into by running wheels w/ no TPM? Thanks
Old Oct 3, 2008 | 04:34 AM
jw34689's Avatar
Zero By Default
nothing .....i think
2. When questioned by a friend's girlfriend, you need not and should not provide any information as to his whereabouts. You are even permitted to deny his very existence.
37. Before allowing a drunken friend to cheat on his girl, you must attempt one intervention. If he can get up on his feet, look you in the eye, and deliver a "fuck off" then you are absolved from all responsibility.
Old Oct 3, 2008 | 08:16 AM
pimpjames's Avatar
42 72 69 6e 67 20 69 74
Your fine. There is a place that replaces the battery in your old ones if you want the cheap route.
Old Oct 3, 2008 | 10:19 AM
2klara's Avatar
Roadkill Vacuum
Thanks
Old Oct 5, 2008 | 09:06 AM
2klara's Avatar
Roadkill Vacuum
Wheels are on.
https://www.tamparacing.com/forums/m...ew-wheels.html
