4L60E rebuild
Old Mar 30, 2005 | 04:09 AM
Half Fast's Avatar
LT1's are slow!
Originally Posted by corey r.
Im gonna rig that button up to Andy's horn!
It already is. He also has the apply bad Ju-Ju now button.
Richard
1996 Corvette CE coupe LT1/A4
Mostly stock
1998 Camaro
Z28 badges and dual exhaust tips
Old Mar 30, 2005 | 04:12 AM
Joe99SS's Avatar
The problem was line pressure. The tranny already had the pressure upped via the custom valvebody and then the tuner was trying to "firm up the shifts" to make drivability better against my wishes. The tuner was ONLY supposed to move the 2-3 shift down a few mph as I was hitting the limiter between that shift. Admittedly it was the first high stall auto car he had worked on and has since probably learned a thing or two and it probably isn't an issue any longer, but it is something to keep in the back of your mind. People are too quick to fix drivability issues with a high stall car by upping the line pressure since the shifts are so soft which is fine, but you can only do it one way or the other, not both at the same time.
Joey
Old Mar 30, 2005 | 10:28 AM
Country Boy's Avatar
can survive...
You know, Ive preached this soooooo many times, but some still dont listen
GT4SOM
Toyota/Lexus Tech
16
Mar 7, 2005 01:53 PM
VetteS10
8
Feb 27, 2005 06:31 PM
Jonas
Feb 13, 2005 10:33 AM
Leonard
May 7, 2004 12:34 PM
Idealsupra
Toyota/Lexus Tech
9
Dec 10, 2003 06:42 PM
