rebuild costs
I'm looking for a rough estimate on costs to rebuild the donor motor for the FFR.
What am I looking at if the following holds true?
Polish crank journals
Bore/hone block .010 over
rings
cam bearings
main bearings
rod bearings
gaskets
(other incidentals i missed)
Longterm (1-2 years after the car is on the road), I want to build up something really potent with an R302 block. (High RPM, High compression.. the whole 9 yards). I'm trying to decide if it's better for me to rebuild this or to pick up a low mileage shortblock, move the heads and EFI stuff over and disassemble the spent block as a learning experience.
rings
cam bearings
main bearings
rod bearings
gaskets
im referring if you goto a shop and have a mechanic pul the block and bore it then rebuild it then reinstall. $3000 easily
trust me, i have done it 2 times now.
03 Gt - SOLD!
88 LX Coupe - 308 with a few mods...
03 Gt - SOLD!
If I were you, I'd get a nice GT40 long block. It will end up saving you money and you will have a nice, reliable motor for years to come. Try contacting Scott about getting one of these.
If I was gonna spend 3k, it would be on the R block, and other assorted bits and pieces.
The point here is: Something sufficient for 1-2 years. < 10000 miles total expected life.
that's what I don't know. if the bores are good and it doesn't need machine work, it can't be that much for bearings and rings. And I'd assume that honing the bores isn't gonna break the bank either.
