drive stick shift weird?.
tried learning on a Spec V with a stage 2 clutch...not too well...
then on a jeep wrangler with a brand new OEM clutch...easy as balls
http://www.hashiriya.net
the clutch engagement was hard for me too.it varies from make to make.I learned on a stage 2 act clutch in my gsr and then I moved to a stock 03 wrx.
-Winston Churchill
-Winston Churchill
this is how I learned to drive manual/standard..and I taught myself:
1)start the car by pushing the clutch pedal(far left pedal) all the way in.
2)put the gear selector into first(upper left)
3)slowly let out the clutch till you feel/see the car moving and then bring the rpms up to about 1500-2000 and let out the clutch all the way...not too fast or it will jerk.
4)to change gears let off the gas
5)press the clutch pedal all the way in
6)put the gear selector into the next gear in sequence.
always remember when you want to slow to a light or anything just put the car in neutral.(can be done without touching the clutch)Then brake like you would normally in an automatic.
hope this helped.let me know if you have any other questions.
-Winston Churchill
-Winston Churchill
Please do not listen to this idiot.go drink some coolant dumbass.
explained all right there also if u jerk from gears to gears it all depends on your timing when u release the clutch and step on the gas lift of the clutch slowly to get it smooth
Like us on facebook
Like us on facebook
lol i already know how to drive stick. im actually pretty good at it. got good in about 30 mins. he told me to get stalled out like 2 times and never did agian. and thats exactly the how to do it. matt. also i have a question. iv seen alot of people press the clutch and brake that way too... does that effect your clutch in any way?
-Winston Churchill
-Winston Churchill
