Ford = Fail
Guest
Posts: n/a
Originally Posted by hachibill
z51 is a suspension option for the vette. it only has leaf springs in the back, and its only one in a transvers location. i know this because i've worked on vette's. in the front it has double wishbone's and a coilover shock.
Oh, I got ya. So GM offers the vette standard with coilovers but a leaf spring is a high performance upgrade for them?
I guess GM doesn't know any better either, because they state here:
includes transverse composite springs
I'm at work, please don't make me find more links showing it has leaves front and rear. I need to get some work done
Guest
Posts: n/a
Originally Posted by FreeThinker
Blah, while I never owned a Stang, I had enough friends with them that I feel like I did the Mustang thing.....
Lightweight yes, good for drag.. sorta, but breaking blocks at 500hp is lame, you have to get a Windsor or Cleveland just to hang with the BowTie guys.
As much as I loathe GM, I would take a Camaro over a Mustang any day...
And last I checked a 302 is a windsor block. No one really builds clevalands, due to the fact there is very little aftermarket support and they arent as easy to come by when you do break one. Chevy 350s also have their limit and its not much higher than a 302 or a 351. All the high horsepower chevy guys will fill their blocks or setup to a Dart/Merlin/GM Bowtie race block. Much the same for the Ford guys as we, they will buy a race block and call it good. With the new engines of the today, the cobra block and heads has gone well into the 7s in the 1/4, GT blocks arent as stout, but they will handle enough abuse for almost anything practical you want to do.
And btw, there are shitloads of 03-04 Cobra guys making 600-800hp are factory blocks.
And please dont pigeon hold to Ford blocks breaking out 500 hp, they arent vary many motors that can do it stock, let along built either. And if they can do it, they arent cheap motors, aka the 2JZ or RB26
It's always opinion, but get some subframe connectors, a good weld-in cage, and find a SHO V6 or even V8...
now that would be a rad domestic drifter.
When they designed the Mustang, driftablity was not a factor they put any thought into. Its a Pony car that makes 300 hp on 87 octane with a single over each head, that spends most of racing past time at the drag strip where the solid axle goes well with. It wasnt meant to be a Vette/Viper killer in handling, just a fun car that handles decently that understeers at the extreme.
The generla jist is, The mustang does well for what it is. You dont see me going into drag racing tech making a comment about how much the BMW IRS sucks for drag racing, due to the fact the BMW was designed to be a drag racer........
ahh, never mind, i was wrong about the front, that makes it even worse though. but if it works it works, ands the only reason i brought up the 4cyl thing is because of advances in technology. my ppoint was you don't need 7.0L's to make 500hp. thats the only point i was making, but if you wanna get gritty about it look at the best engine on the planet....2jzgte. what other engine can make over 1000 wheel hp on a stock block motor from the factory and do it just as reliably as when it cam from the factory. the only point i was tring to make is the fact that american cars now have the same build quality and technology as japanese cars did 10 years ago,
its not that i was sayong the new american cars aren't good, its just the fact that everyone is all about ohh, ahh look what america can do, and the japanese did it 10-15 years ago. putting forged cranks in late 70's and early 80's corolla's and celica's. to me it just seams that the desighn stuff backwards. if the LS1 and all these alluminum small blocks had DOHC's and variable cam timing, ITB's they would be making way more power at the same displacment. not saying you need VTEC or any crap like that, but if toyota can make a 1.6 n/a 4cyl make 170hp and rev to 9k stock why can't america?
Not only that, but those motors need RPMs to increase their usable power.
I do agree with you on not needing 7 liters to make 500 hp. You only need 4.6 and a few mild bolt-ons.
One thing I notice is that when the v8 v. 4cyl thing (and import v. domestic) starts up, it always goes into car quality which has NOTHING to do with any of the arguements at hand. I'm an all around car guy, I like them all, but gimme a break on the quality crap. All of the early 90's cars I have had (import and domestic) have all been pretty much crap for interior...it's just the era that they were built in. Plus, if you're just into dedicated track cars (drag, drift, autocross, roadrace), what is the first thing to go? Interior. The end.
#1. The Corvette uses leaf springs FRONT and REAR. Actually A leaf spring in front and 1 in back also. But you're totally out of the ballpark for trying to criticize GM on that design. I'm a guy that will rarely defend GM, Like I said before, I personally like Ford better, but there is nothing wrong with a transverse composite leaf spring. It fits neatly underneath the engine and rear tranny, and just has end links like a swaybar, so it's very space effecient.
Ohh noess... F1 cars use torsion bar suspension and so does the F150, F1 cars are so using crap truck tehcnology..... yea, absolutely retarded comparison.
#2. Despite widespread misconception, a solid axle is NOT the best for drag racing. It might be the easiest most thoughless setup, but what are teh chances that the same suspension found on a conestoga wagon would work good for some form of racing..... yup. very little.
The problem is that the driveshaft tries to twist the axle, and the opposite reaction is the car body twisting the other way. The left rear tire plants a lot harder, the left front tire comes off the ground and in a high HP car it's pretty easy to meet Mr. Wall.
The best drag setup would be a double wishbone setup with equal length wishbones at equal angles so there is no camber arc and you set it for zero camber.
There's also a simpler design that has more unsprung weight, but would be easier for the drag guys to dial-in. It's called a DeDion rear suspension. Look it up on google for some pics, but it's basically the solid axle you would see in the back of some FWD vehicles, with a diff mounted to the car's body, and halfshafts connecting the diff to the hubs. It isolates lateral drivetrain torque from the suspension, but you can still set it up as a 4link
Go find some video of the RX7.com drag car form a few years back and watch it run 8's launching straight as an arrow every time, no twist, no drama. it has IRS
#3. Uneven tire wear 'suffered' by IRS cars is from poor setup, just like twist and sideways launches in drag cars. I've crewed a few race teams and at every track we used pyrometers and checked 3 points on the tread width during practice every 10 laps or so. This is to dial in the camber properly. Most drifters have their cars too low for the stock geometry to work properly. Plus they are running way too much baseline camber anyway, but but if they corrected the camber, their camber arc would still be too aggressive for the spring rates (because of the upper control arm angle).
I rocked stock BMW ride height and a single set of tires all day at MiamiSlide1 and at the end of the day I wasn't showing threads anywhere, but I had perfect slicks. But IRS sucks for tire wear??? right...
About the only cool thing about a solid axle is you can go as low as you want and it doesn't change, plus your roll center actually gets higher. (high roll center is good)
-Sean
-Sean
At a given day and a given circumstance, you think you have a limit. And you then go for this limit, and you touch the limit, and you think "okay, this is the limit". As soon as you touch this limit, something happens in you so that you can go a little bit further. With your mind power, your determination, your instinct and your experience as well, you can fly very high. - Ayrton Senna
Guest
Posts: n/a
And so what if the solid axle was used on a wagon. If it works for its intended application, then it works. I'm beginning to think Hachi Roku is Japanese for "if its old and American, it sucks".
