need help what would casue this ?
Old Jul 1, 2011 | 02:17 PM
  #91 (permalink)
GNs-r-slow's Avatar
Bondsman
Look more what the boost values are when the issue happens not rpm. at 6k in third, you may have less boost and load then in fourth at 5k.
Old Jul 1, 2011 | 05:28 PM
  #92 (permalink)
st pete chad's Avatar
if i run it just off the wastegate which is 9.8 psi it has yet to do it.i called edelbrock and told them what was going on and they said if i was spinning more RPM and more boost then yea maybe valve float but being im trying to pull 6200RPM and only 14psi he said hes almost 100% sure its not the valves.
one on the guys on here bullit proof had the ford racing svo heads or whatever they are called and hes has no issue with his so i dont see how the edelbrock would fail so now im lost i have no clue what else to try
[IMG][/IMG]
357w s475 turbo Hughes powerglide
Old Jul 2, 2011 | 08:04 AM
  #93 (permalink)
GNs-r-slow's Avatar
Bondsman
Didnt see where you answered, but where are you sourcing your vacum from for wastegate and electronic controller?
Also wastegate springs arent going be exactly acurrate. Have you tested the spring pressures with air to verify where they are opening the WG at? Your boost gauge reads 9.8 psi???
Old Jul 2, 2011 | 10:52 AM
  #94 (permalink)
vacum is coming from the turbo.as for testing the wastegate no i havenot done that.im thinking it might be coil bind but im not 100% sure yet.i was told my 1.72 might be to much for the stock springs
[IMG][/IMG]
Old Jul 3, 2011 | 09:39 AM
  #95 (permalink)
ok so i tryed and replaced the TFI module with another one i had and it still does the same thing.so i tryed to free rev it and it goes to 6000 easy but at 5000 it feels like it has a miss just for a split second
[IMG][/IMG]
Old Jul 3, 2011 | 08:18 PM
  #96 (permalink)
harold harper's Avatar
h9
I figured out Ha..Ha..!!!
Old Jul 3, 2011 | 08:22 PM
  #97 (permalink)
Tiffiny's Avatar
I can fix your bullshit
what took you so long......its just a ford...lol
Old Jul 3, 2011 | 08:52 PM
  #98 (permalink)
I you mean we? lol still cant believe it was something so stupid.now all i need is a clutch seeing that now the fucking smoke the clutch so bad it barley moves
[IMG][/IMG]
Old Jul 3, 2011 | 08:58 PM
  #99 (permalink)
Tiffiny's Avatar
well what was the problem
Old Jul 3, 2011 | 09:10 PM
  #100 (permalink)
this piece in the picture the damn roller pin was missing and the damn shaft kept coming up throwing timing off and whatever else it could have been doing.its good its figured out but the bad thing is the poor clutch dont have a chance to hold it and the damn things slips so bad the car dont even increase MPH.also the coil,TFI module were bad.so now im going to put the spec stage3+ in it and it should make 650 plus
[IMG][/IMG]
