Ultimate cooling system for a high HP Fox
Old Mar 8, 2011 | 04:41 AM
Razor's Avatar
Originally Posted by cochese
electric water pump, fan blowing from the front of the rad, 16 volt battery, no stat..... thats what I run, after my run I just leave the pump and fan on and have no problems cooling. You could put a 16v alt on it also
What do you do for warm up. I mean with a stat the water doesnt circulate until it reaches the opening point.
Did you wire the WP along with the fan through the XFI?
On mine the XFI controls the fan.. but I have it set to activate at 187 and shut off at 177(180 stat)
Maybe set it to 160 and wire both WP and fan together? Thoughts...
NEW Machine
89 Mustang GT
9.040 at 153.13 1.502 60ft Hoosiers 275/60 Jan 2012
True-Street trim
348, 88 t4 .96, pump gas
www.alkycontrol.com
Old Mar 8, 2011 | 06:25 PM
Iraq&Roll's Avatar
I run a Ron Davis radiator with the 2 fans and a Meziere pump. My inter-cooler is a horizontal mount but I also have an a/c condenser. Been thinking about adding a pusher fan in the front.
I had been dealing with engine issues pressurizing the cooling system so I can't say how well it does or does not work. My turbos are water cooled and that does not help.
I will be looking into an oil cooler soon.
General Stonewall Jackson has been quoted saying that when the time of war comes,
“My advice is to draw the sword and throw away the scabbard".
Old Mar 8, 2011 | 07:21 PM
Tiffiny's Avatar
I can fix your bullshit
maybe you can make a sheild of sorts between the rad and down pipe...
Old Mar 20, 2011 | 04:45 PM
Razor's Avatar
Wanted to update. I went with the Meziere 55 gph unit and it ended up doing the job fine. The notes on the install .. the belt needed to be .5 inch shorter, supplied allen head SS bolts where .125 too long, and the power steering bracket needed to be cut to fit over the outlet. Water temps during a 30 mile cruise hit a high of 180 at 2300 rpms.. and idling it for a little while temps came down. This was run no thermostat.
Update on my "True Street" outing this past weekned.. made the cruise fine.. first pass 9.84 at 138 on a 1.5x 60 foot.. second pass as soon as I did the burnout.. Aeromotive pump died and lost pressure. After I let it cool off.. it came back to life.. what a bum deal.. but hey thats racing.. new pump will solve the maladies. That pumps been on the car for 5 years at least.
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
Old Mar 20, 2011 | 05:24 PM
subbie racer's Avatar
i heard that airplane coolant works good, was at a classic car meet and they were talking about that
MiniBoost
Old Mar 20, 2011 | 08:31 PM
Miles.'s Avatar
Previously 19-camaro-88
I know your power level is way above what I'm about to describe but it may help others with similar problems. When I built Airborne's car we had trouble keeping it cool. We had a champion radiator, stock fan, stock water pump and a crate ordered stock 302 and couldn't keep it cool. Tried everything I could think of. Then we heard to try baby drinking water and water wetter.. after that, never had a problem again....
-Miles.
Old Mar 23, 2011 | 10:45 AM
  #17 (permalink)
TurboSteve's Avatar
A good healthy battery will run the fan and the pump while you're in the lanes. Alternators are key, and you probably need a good 200-amp alternator to properly charge the battery--you are running a lot of electrical equipment on that thing. One thing to keep in mind with alternators is that they aren't necessarily throwing 200 amps at idle. Most have an rpm or engine speed at which they start charging. PA Performance can give you the dirt on this.
Another key is having a fan that doesn't draw a lot of amps. Many of the factory fans do just that, so oftentimes the aftermarket pieces are better. Spal and Flex-A-lite offer relatively low-amp fans.
Beyond that, you may need to make some mods to the front to get more air through or past the intercooler.
Oh, and wrap that pipe! It can cause the hose to prematurely weaken and fail.
05stisilver
Car Audio For Sale
May 9, 2007 10:10 AM
I-NEED-VTEC
Apr 21, 2005 06:17 AM
terry.ho
Dec 13, 2003 05:03 AM
F4A22
Nov 22, 2003 05:35 PM
94teg
Feb 25, 2002 09:13 PM
