need help with cooling system
Here's the deal. I have a JDM B16. The motor was running on cold while driving. So I replaced the thermostat, or lack there of, with a jackson racing 160 degree thermostat. My car didn't have a thermostat when I pulled the housing apart. Now I can let my car idle all day long and the temp reads normal. I start driving for a little while and the temp goes up. As soon as I crank the heat to high it drops immediatly. I hard wired the fan and it does the same thing. I have bled the system numerous times and that has not help either. Any ideas????
http://www.myspace.com/terry_ho
IF its not leaking/losing fluid is it ?assuming there are no leaks & the cooling fan is working,check the water pump for leakage,Also be sure that the radiator is circulating antifreeze & has nothing blocking the the fins on the radiator.....
813-377-5505
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Originally posted by `92CXhatch
i still say hot wire that fan and then try her out... if that is it then it is the relay switch... if the fan doesnt come on when hot wired then it is the fan... pretty simple!!!
-Keith
-Keith
There are no fluid leaks. And it is still doing it. This is going to drive me to drink.
water temp sensor?
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
Originally posted by chi town brat
water temp sensor?
water temp sensor?
I thought that too. but it doesn't make sense that when i turn the heat on the temp drops off.
That was the next step. I have an extra one os I'm going to change it this weekend. It's just strange that the motor didn't have one at all.
