Ultimate cooling system for a high HP Fox
Old Mar 7, 2011 | 05:15 AM
Razor's Avatar
Default Ultimate cooling system for a high HP Fox
Need to get my cooling temps under control. 800 HP
My current setup is a Griffin Aluminum Radiator, MK VIII fan, 180 stat, and new WP.
I need to get temps down quickly without opening hood... electric water pump?? But which one?? Isnt there one that is both mechanical and electric?
Radiator?? what fits a Fox and cools it down quickly.. any cutting??
Battery? what wont run it down.. run 2 batteries? Run one just for Fan and water pump.. the other for running the car?
NEW Machine
89 Mustang GT
9.040 at 153.13 1.502 60ft Hoosiers 275/60 Jan 2012
True-Street trim
348, 88 t4 .96, pump gas
www.alkycontrol.com
Old Mar 7, 2011 | 06:27 AM
500HPLX's Avatar
The dual Contour fans are supposed to be the shizt. I am going to be trying one of those out soon on the red car.
You have a oil cooler? That may help also.
How did you do this week end? Saw you first pass Sat morning. that thing moves out real nice.
Old Mar 7, 2011 | 06:32 AM
Na306StAnG's Avatar
Flowmaster nut swinger
I'd say the radiator is more then capable. What brand W/P are you using now?
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Mar 7, 2011 | 06:58 AM
Razor's Avatar
Won the 10 average with a 10.04.. got a 100 dollar check
The turbo's down pipe is to close to the rad on the pass side.. so an extra fan there is an issue. I saw that article for the fan on the MMFF mag a few months back. Thanks for the tip..
No oil cooler.. never though of running one.
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
Old Mar 7, 2011 | 07:12 AM
Razor's Avatar
Stock aluminum WP. Thought it was an edelbrock piece.. but its been a few years. Car runs at 180 at 65-70 MPH no problems. I think an electric is the deal.
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
Old Mar 7, 2011 | 04:42 PM
cochese's Avatar
Chucking up the Dueces
electric water pump, fan blowing from the front of the rad, 16 volt battery, no stat..... thats what I run, after my run I just leave the pump and fan on and have no problems cooling. You could put a 16v alt on it also
Induction Performance.com
PTC torque converter
Aerospace Components
ProFab Performance
R.I automotive
C.R.T transmisions
5.13@145mph
Old Mar 7, 2011 | 05:17 PM
GNs-r-slow's Avatar
Bondsman
Go to a ice/water tank and sell the radiator.....many have to put a ball valve in-line to throtle the flow to get some temp in the motor and only seeing 150 at the end
Old Mar 7, 2011 | 06:12 PM
herrcomestrouble's Avatar
what coolant mix are you running? Purple Ice/water wetter shit works! way cooler than straight water or water/antifreeze...
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old Mar 7, 2011 | 07:12 PM
GNs-r-slow's Avatar
Bondsman
I have a low mileage Moroso electric water pump if you're interested in going that route. I bought it from Cochese, he can verify condition. Im going with ice/water tank set up with a Rule bilge pump
http://www.jegs.com/i/Moroso/710/63585/10002/-1?CT=999
Icludes this fitting also
http://www.jegs.com/i/Moroso/710/63543/10002/-1
Old Mar 8, 2011 | 04:38 AM
Razor's Avatar
The problem is the car gets driven on the street. The class I like running is required to drive 30 miles. If it was a straight race car I would understand.
I cant put the fan in front of the radiator due to the A-A IC.
I went out and bought the 55 GPM Meziere with pulley. I figure the radiator I have(Griffin aluminum) should be plenty.. I'll take out the stat and install pump.
Suckers expensive but so is a new motor. Last weekends 3rd pass was done at 237 at the line and 244 through the traps. Never do that again..
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
