Need Help, Badly
The Fox computers control the idle rshared_pm by varying the timing so it may have a bit of affect. On my data logs, I see mine jump between 10 and 26 degrees at idle. I can't seem to get that worked out of it but the current tune seems to keep that under control better...time will tell. I would say your problem is probably a vac leak or exhaust leak that is messing with you. Exhaust leaks can pulse fresh air into the exhaust and your 02 sensors think you are running lean so they command more fuel to compensate. That causes you to run rich so the computer compensates the othe way and ends up chasing its tail. The result is suring and stumbling. Another thing you might do is to remove the electronics from your MAF and gently clean the little coils with an electronic cleaner that doesn't leave a residue. Sometimes you get a little oil on those coils, especially if you're using a K&N type filter that uses an oil on the element. You can suck up a little of the excess oil, especially i you clean and re-oil the filter and get a little too much on it. That oil can screw with the readings and result in some wacko problems. Couldn't hurt to clean it...just be gentle with those little filament coils.
YO! Barry! You LOST!
Didn't mean to say that varying timing is the only thing that controls the idle, obviously the IAC is a major part of it.
Speaking of which, when you cleaned the IAC, did you also clean the passages for it in the throttle body? They are probably full of the same crap that was gumming up the IAC.
What does it do if you disconnect the IAC when it is idling?
When cold it is likely to stumble and cut off, when warmed up it should not make any difference. If it just cuts off no matter what, I doubt the IAC is the problem. You may need to do a idle adjustment and start it from scratch. I tried several methods and finally found one that actually worked. I think it was in a Ford bulliten or something I Googled.
I have not read the full post, so forgive me for jumping in like this.
I went around with my set up when I put on a H/C/I and then a Novi. Things got interesting and I learned ALOT!
You still have the same situation except you're dealing with 4 degrees extra instead of the 7 degrees extra. A lot of guys without tuners bump their base timing to 14, however, and don't have any problems. The stock Ford programming for the most part is pretty conservative. It's just something you need to be aware of if you don't have a tuner, that changing your base timing affects timing everywhere and that sometimes that can be bad. You should be fine at 14...you may be fine at 17 but that's pushing it.
I had a couple
while I was reading that.
TurboRAM Member #5
24psi & Stable
GET SOME
