Need Help, Badly
Old Apr 4, 2010 | 08:15 AM
Superwes98's Avatar
yea that was the first thing i checked and got a new gasket for it
Old Apr 4, 2010 | 05:53 PM
Superwes98's Avatar
do u guys know which wires i connect the multi-meter up to?
Old Apr 4, 2010 | 06:16 PM
DrDirt's Avatar
Team Geritol Racing
Well, crap, I thought I had one out in the garage but I can't find it. From my not-so-good memory, I think you stick a needle or pin into the green wire (sounds wierd but I don't even remember what color wires are there) and connect the multimeter to that. Look on the Corral in their tech articles. I think they have a how to on setting it and which wires to use. It's easy for me, I've got the Moates Quarter Horse for tuning and I just start a log s e s s i o n and look at my laptop and see what the reading is. Then I just move it around till I get about .98 volts and lock it down.
YO! Barry! You LOST!
Old Apr 4, 2010 | 06:36 PM
SVT1996Cobra's Avatar
What?
green wire is positive, black is ground.
be sure to check the voltage with the throttlebody closed first, then move the throttlebody blade to WOT and watch the voltage as you do this. It should slowly rise, if it jumps around you probably have a dead spot and need to replace the TPS
Old Apr 4, 2010 | 06:38 PM
Superwes98's Avatar
oh ok, gotcha
but yea, theres a red green and black wire
Old Apr 4, 2010 | 06:39 PM
What?
n/m, it's late
third wire should be orange, not red
Old Apr 4, 2010 | 06:41 PM
  #17 (permalink)
Superwes98's Avatar
wat is WOT?
and do i do this while the car is running or off?
Old Apr 4, 2010 | 06:53 PM
  #18 (permalink)
DrDirt's Avatar
Team Geritol Racing
No shit! So Alzheimers hasn't fully set in yet, huh? Imagine that.
Old Apr 4, 2010 | 06:54 PM
  #19 (permalink)
What?
Wide open throttle. car off.
this may help alittle.
Summarized/Corrected Base Idle Reset Procedure
you just need the TPS part.
Old Apr 4, 2010 | 06:57 PM
  #20 (permalink)
What?
key on, engine off
