HELP...car broke down
My problem ended up being a bad inner peice of the dizzy. I beleive it was the stator? Either way when it would warm up caused all sorts of hell. That along with the pip controls the fuel pump on the efi cars and was actually stopping and starting the pump when it got hot. That was once of the most pia thing to find I ever had on that car, bet I spend 3 weekends fiddling around with it before I got it narrowed down.
Hope that you get it figured out.
Yeah the stator/pickup. I went thru that problem about a month or two ago, fucking drove me crazy tracking it down. It would be drive fine except for putting a heavy load on it.
SUCH IS THE RULE OF HONOUR.
I have the original 4180 Ford/Holley sitting in storage and I'm tossing around the idea of a rebuild to save some money. I know jack shit about carburators, but I really want to learn the in's and out's....so I'm thinking maybe tackling a rebuild would be a good way to learn. Does the Holley rebuild kit provide thorough enough instructions to complete the task? I'm confident I can tackle practically any mechanical task so long as I have a good set of instructions and the proper tools/parts.
Yes the instuctions are very good, if not pick up a haynes manual (carb rebuild)
But Steve is right about the tools needed, just make sure you have a big ass can of carb clean to soak it all in, getting it all clean is the biggest thing.
Bring the old carb over here along with the rebuild kit. I'll have it back to you in a day. Or, just bring the car over here with a new Holley Street Avenger like I have and it'll be fixed in 10 minutes and running/idling like a champ.
Install that coil I gave you and run new wires as far as you can as well. Additionally, make sure you've got a clean fuel filter on it and a way to check how much fuel pressure you've got. Sounds a lot like the fuel pump is getting old and when combined with the fuel leaks/crappy carb that you're not getting enough fuel pressure.
1973 VW Squareback
1979 AMC Jeep Cherokee Chief
RIP Tim
1973 VW Squareback
RIP Tim
I'll stick by my Street Avenger recommendation as it started up a car that hasn't run in 9 years with no fiddling whatsoever. In addition, not even the idle screw needed to be tweaked, mine idles right at 750.
1973 VW Squareback
RIP Tim
1973 VW Squareback
RIP Tim
Levi, I swear to christ if I ever hear you use the term dizzy again I'll....uh...not be your friend any more.
Its a distributor in America!
Oh, and Alan, sorry I can't help with your problem, but I hope you get it squared away
Ended up being the coil wire contacts or lack there of.
Need to move that coil off the block soon !
9.31 @ 148.12 ( Drag radials, street driven, low boost, no fancy race car shit....
___________________________________________
TR's Official In House Realtor
PM or E-mail Me If you are Looking To Buy/Sell/Rent A Home.
Special TR Bonus For Using My Services.
Coil wire is fixed. Car runs well, but still has a low idle issue and of course gas is leaking from the front and rear bowls.
Come to find out that this carburator on my car was a remanufactured carb by some place called Pony Carburators who "specializes" in rebuilding and modifying the 4180 to cure it of many common issues. Perhaps this carburator isn't complete garbage just yet. Would it be worth my time swapping out the bowl gaskets? Would I even have to remove the carburator from the manifold to accomplish this?
