need help on igniton problem on an 89 mustang
Old Dec 18, 2005 | 05:11 PM
blown1989stang's Avatar
Default need help on igniton problem on an 89 mustang
went to try and turn the car over not start it and nothing happends i have no power to ignition at all is there any way to run a toggle switch to jump it from the starter cylinoid to the key??????????????
Old Dec 18, 2005 | 06:22 PM
nasdstang's Avatar
need turbo stuff,pm me
use a test light to find the ignition wire wire from key, make sure it stays hot while cranking, then just run a wire to the little push on plug at the solenoid.
-Ronald Reagan
Old Dec 18, 2005 | 06:32 PM
its not hot period that is the problem
Old Dec 18, 2005 | 06:33 PM
its not hot at the key at all
Old Dec 18, 2005 | 06:34 PM
a98ss's Avatar
take the little white wire off the solenoid and leave it hang,then take a piece of wire and put it on the hotside of the coil and run it to the + side of the battery.once you have done that stick a screw driver on the little post and the other post of the solenoid
Old Dec 18, 2005 | 06:35 PM
$hawn's Avatar
lives in a glass house
If you dont want to track down the real problem run a hot wire to one side of a push button switch and the other lead to the small terminal on the starter solenoid as nasdstang said.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Dec 18, 2005 | 06:38 PM
i have no white wire i have the ignition wire the battery to solenoid soleniod to starter and the other one is brown orange with a white strip and the other wire is yellow
Old Dec 18, 2005 | 06:40 PM
alright thanks guys i appreciate it tried to start it for the first time today thanks alot
Old Dec 18, 2005 | 06:42 PM
nasdstang's Avatar
89... take a wire from the hot side of the solenoid, there are two wires going to your coil, one has green and one has red, stick it in the red one, now.. take a screwdriver and jump the solenoid, if the car starts and you want to turn it off just unhook the wire to the coil
-Ronald Reagan
Old Dec 18, 2005 | 07:21 PM
JDL1000's Avatar
If your unfamiliar with the electrical systems on these cars find someone that is to fix it. I've seen too many of these cars go up in flames because someone just rigs the wiring. And from what I've seen these cars burn all the way to the ground.
Life moves pretty fast. If you don't stop and look around once in awhile, you could miss it.
-- Ferris Bueller --
