need help on igniton problem on an 89 mustang
Old Dec 18, 2005 | 08:44 PM
  #31 (permalink)
blown1989stang's Avatar
well i will let u guys know whats going on after i try somethings tomorrow thanks everyone
Old Dec 18, 2005 | 08:51 PM
  #32 (permalink)
JDL1000's Avatar
Take a screw driver and with the key in the run position (make sure the car is out of gear) jump the solenoid. (Stretch the screw driver across the battery side of the soleniod and the small connector on the seleniod. Just pull the small wire off the soleniod for this test. )
Life moves pretty fast. If you don't stop and look around once in awhile, you could miss it.
-- Ferris Bueller --
Old Dec 18, 2005 | 08:53 PM
  #33 (permalink)
JDL1000's Avatar
If you do this and the car trys to start you have a problem with the ignition switch or the wire inbetween the ignition switch and the solenoid.
Old Dec 18, 2005 | 09:04 PM
  #34 (permalink)
JDL1000's Avatar
I sent you a pm with my phone number .You can give me a call tomorrow if you want some help. I can probably walk you through some quick tests to try to help you.
