Gears?
Old Apr 6, 2005 | 04:13 PM
  #21 (permalink)
BDIX's Avatar
Dick is Huge!
what heads/cam/intake are u running?
Totalled his shit!@
Old Apr 6, 2005 | 04:47 PM
  #22 (permalink)
TheShow50h's Avatar
The little 5.0 that could
+1, especially cam... specs could give a lot of us a pretty good idea on where your making your power.
-Vince
Old Apr 6, 2005 | 05:42 PM
  #23 (permalink)
stockstang's Avatar
The Pit Stop
Ok I have edlebrock heads, cobra intake, 65mm throttle body, 76mm mass air, 24 lbs. injectors, and a custom grind cam, pulleys, LT's, H-pipe, FM's, all on a 306 bottom end. Not sure on the grind and I know that means it could be set up to make the power any where. All I know is it doesnt cam real ruff but you can tell it has a cam. Previous owner had the motor built and I never got the spec card on the cam.
So should I dyno first to see what gear would work best?
Old Apr 7, 2005 | 12:47 PM
  #24 (permalink)
Joker34624's Avatar
ive had both in my 99 cobra i like 410 but i run 1/8 mile depends on what you using it for 373 are a better all around gear in my opinion
Old Apr 7, 2005 | 12:52 PM
  #25 (permalink)
TheShow50h's Avatar
Without a doubt, making a couple baseline pulls at fordspeed or racerelated shouldn't cost more than $50-75.
-Vince
Old Apr 7, 2005 | 01:14 PM
  #26 (permalink)
kenny c's Avatar
put more stickers on it
yep... with what you have, i would say 320ish... if you have the $$, then dyno it, get the gears, then back to the dyno for a custom chip
Old Apr 7, 2005 | 03:58 PM
  #27 (permalink)
N20D5OH's Avatar
Originally Posted by Fabricator4Life
i have put many sets of gears in cars your best bet would be to go with 3:73. 4:10 is a little much for a daily driven 5.0.. i work over at race related if you have any questions just call 727-561-9440
Wow, I guess my 4.56's are way too much for my daily driver.
With an S/N-95 I wouldn't go any lower then 4.10's with a manual. I had them in my '94 and it did just fine. If you're worried about gas milage, buy a Honda.
2013 Base Mustang GT - Tampa Stock
alri0085
Mar 6, 2005 07:20 AM
kender
May 19, 2004 06:42 PM
alainandsilvia
Nissan/Infiniti Tech
9
Apr 27, 2004 11:30 AM
jdmef9
Mar 25, 2004 01:14 PM
