Carb or EFI
Old Apr 5, 2005 | 01:36 PM
  #21 (permalink)
Stangonline's Avatar
If you can use a computer, EFI...
If you can barely count with your fingers, carb...
Jeff
93 Coupe - check out my blog - http://www.93coupe.com
01 Cobra - Stockified - Wife Owned and operated
68 Coupe PROJECT <- Been in the family for 25 years!
Old Apr 5, 2005 | 02:50 PM
  #22 (permalink)
cantgetenough's Avatar
02 Saleen
White Stallion.......let the horses run!!!!!
Old Apr 5, 2005 | 04:34 PM
  #23 (permalink)
RS20R03's Avatar
How Fast???
hey thats a nice looking ranger you have.....it will look good with Saleen rims and that 302 will give you more than enough power.....
"There are some that like it stroked and others like it blown"
"I like it stroked and blown at the same time!!!"
-RYAN-
AIM- rs20r03
TO EMAIL ME CLICK HERE
Old Apr 5, 2005 | 05:01 PM
  #24 (permalink)
Flastangs's Avatar
Default Ranger V8
Their was a very nice Ranger V8 at NMCA for sale but it was $13,500
Old Apr 5, 2005 | 07:29 PM
  #25 (permalink)
stangerang's Avatar
whoopdy fucking do!
hmmm, if your going with a carbed setup and sttarting from the ground up i would look for a different block, maybe an older, non roller block........ cheaper parts and easier then peicing this here that there, and i hear the older pre EFI blocks are stronger......
200 points away from a 300
Old Apr 6, 2005 | 01:04 PM
  #27 (permalink)
69Boss521's Avatar
PORK CHOP SAMICHES!!!!!
i'm pro 351w. It all comes down to what are you wanting?
Derp!
Old Apr 6, 2005 | 05:15 PM
  #28 (permalink)
02 Saleen
Originally Posted by Mars_302
If its going to be a Daily Driver then do EFI. Order the Painless wiring harness kit. If ally ou wanting to do is 350 just stick with stock internal. Hell stock internal are good for 450-500 hp anyway.
If I were going to do it. it be..
Stockblock
Eagle ESP Con Rods ($230)
Stock Forged Pistons that are flycut ($250)
Stock crank, get a new fresh one acutally ($100-$200)
....all balanced together
TFS Stage 1 with 1.72 Roller rockers or a TFS Stage 2 or even a FRPP F or X cam (130-$170 for the cam, $100-175 for the roller rockers used)
Self ported Explorer intake ($200used) or
Holley SysteMax II Intake ($500 new)
Explorer Throttlebody($50 used)
24# Injectors($75 used if you look around)
Holley or Edelbrock heads ($800ish used if you look around)
ARP Bolts all thruout ($250ish for everything)
Timing Chain cover ($75used)
New water pump($40)
Misc other shit, like gaskets, oil pump, timing chain ((budget around $200 tops)
Mac shorty headers ($50 used)
Painless Wiring harness kit ($450)
190/255 LPH fuel pump($110)
some other bs as well like finishing the exhaust and how to run the fuel setup itself
thats sounds good. now i cant decide what to do. i need to get the bottom end built and heads put on then ill deside to go with carb or EFI. im going to go with all new internals also.
Old Apr 6, 2005 | 06:35 PM
  #29 (permalink)
RS20R03's Avatar
How Fast???
buy a .030 over rotating assembly with forgered or hypereutectic aluminum pistions from jegs or summit, they are pretty reasonable prices.....
-RYAN-
AIM- rs20r03
Old Apr 7, 2005 | 11:24 AM
  #30 (permalink)
69Boss521's Avatar
+1 summit, have never once had an issue with them. Even when I ordered the wrong dizzy, they exchanged it no problem for me.
Derp!
