fuel pressure
Old Mar 2, 2005 | 01:49 PM
DrDirt's Avatar
Team Geritol Racing
Originally Posted by Drewpw4ng
ok so let me get this straight.. sorry if i sound like a retard but i really dont know how this works. The threded stud on top is set up for a fuel press line/gauge?( does it be topped off with either a gauge or line or can it remain open) the vacuum line bove the allen head is where the stock vacuum line off the intake manifold goes? and u just adjust it from the allen? could i move the gauge to the regulator for easier access to it? thanks again ...
oh why would my stock fuel press be at 30 idle and not 39?
No the threaded allen head on top is for adjusting the pressure. There should be a nipple on the side for the vacuum line to fit on. Depending on what regulator you have, there may not be a provision for a pressure gauge on it. What regulator is it?
The gauge reading will change after you hook the vacuum back up. Do your adjusting without the vacuum attached.
YO! Barry! You LOST!
Old Mar 2, 2005 | 06:13 PM
Drewpw4ng's Avatar
stock :-\
okay i get it thanks a bunch i got a pic of it ill post it up
Old Mar 2, 2005 | 07:39 PM
SoL_93GT's Avatar
11.5-12 is a pretty safe air fuel ratio, I personally don't let mine go above 11.5. What air fuel ratio are you looking for?
Briane
Red 93 GT with only 9000 original miles on it.
HP Performance Stage 1 Street kit with 60mm turbo
Car Pics
11.29 @ 126 mph 16 psi
16 lbs of boost 509 rwhp/626 rwtq
12 lbs of boost 433 rwhp/571 rwtq
********STOCK MOTOR*******
Old Mar 3, 2005 | 04:55 AM
DrDirt's Avatar
Team Geritol Racing
An AFR of 11.5 is great for a turbo or blown car at WOT. For normal driving though you still want it around 14.6. The stock setup, on the Foxes anyway, is a bit rich from the factory even for a stock car. That's what's taking me so long tdialing my car in. I've got it pretty good at normal driving now and am a bit rich for the most part at WOT...but I'm lean at idle. Just have to keep wcrewing with all the parameters with my Tweecer. I'll whoop it yet.
Old Mar 3, 2005 | 04:59 AM
Drewpw4ng's Avatar
stock :-\
Briane
around 12.5ish at WOT. im picking up a C&L 76mm today for my 19s and gonna put the regulator on and play with it today. thanks for ur help guys .. ill get that pick of the aeromotive today
Old Mar 3, 2005 | 08:19 AM
  #17 (permalink)
DrDirt's Avatar
Team Geritol Racing
Look in my gallery. Is it similar to the one I have pictured? That one is for later model Mustangs but the Fox one is similar, just a little different shape on the bottom. If so, then what I said above applies.
Old Mar 3, 2005 | 08:35 AM
  #18 (permalink)
Drewpw4ng's Avatar
stock :-\
yup thats it ..mine jsut has the bronze allen head below the vac line.. which is for the gauge correct?
Old Mar 3, 2005 | 02:12 PM
  #20 (permalink)
DrDirt's Avatar
Team Geritol Racing
Yes, the brass allen head is probably just a plug.
Alan
Apr 17, 2004 02:14 PM
Cronic
Feb 14, 2004 03:04 PM
Goopster1
Nov 14, 2003 07:44 AM
4.6Power
Nov 11, 2002 06:45 PM
