PRO M 80mm?
Old Jan 20, 2005 | 05:56 PM
Stangonline's Avatar
Pro-M sells their 80 all the time for N/A stock cars.
Jeff
93 Coupe - check out my blog - http://www.93coupe.com
01 Cobra - Stockified - Wife Owned and operated
68 Coupe PROJECT <- Been in the family for 25 years!
Old Jan 20, 2005 | 07:01 PM
1BAD347's Avatar
Whats in a Title
I think the 80mm works better on boost applications or bigger cubic inches (strokers). Pro-M is a very good unit and it can be recalibrated later on.
Old Jan 20, 2005 | 07:09 PM
SoL_93GT's Avatar
Not for stock 87-93 cars they don't. An 80 mm meter supports 800 hp, I'd be willing to bet you $20 they will not recommend a 80mm meter for a stock 5.0.
Briane
Red 93 GT with only 9000 original miles on it.
HP Performance Stage 1 Street kit with 60mm turbo
Car Pics
11.29 @ 126 mph 16 psi
16 lbs of boost 509 rwhp/626 rwtq
12 lbs of boost 433 rwhp/571 rwtq
********STOCK MOTOR*******
Old Jan 20, 2005 | 07:32 PM
Drewpw4ng's Avatar
stock :-\
i just have shorties.o/r h pipe ,flows, little head work, and minor bolt ons. i plan to eventually do a h/c/i setup simular to show50hs combo. I was looking at like a cheap explorer 65mm/egr with the 80mm and intake elbow. think that setup would work nicely and give me a few ponies?
Old Jan 20, 2005 | 07:41 PM
SoL_93GT's Avatar
http://www.cnlperformance.com/76mm_86-93.html
You should get this, it comes with a 76 mm meter and an elbow kit. 80mm is too big for your stock motor. Too big of a meter on a stock engine will decrease the velocity of the incoming air and you will loose power on the low end (tq).
Briane
Car Pics
Old Jan 21, 2005 | 09:40 AM
  #17 (permalink)
$20 please.
It used to be that too big of a meter on a car that wasnt moving as much air was a no-no. Metering has gotten better over time. As long as it can accurately meter the air, it doesnt really matter what is done to the engine. I know a pro-m dealer and he has sold money 80mm meters cal'ed for 19lb injectors. Hell, I even have one on my shelf!
Jeff
Old Jan 21, 2005 | 09:42 AM
  #18 (permalink)
Briane
Your thinking about a throttle body. If the meter measures the air correctly, its not going to effect the tq, but too big of a TB or anything after the tb will.
Jeff
Old Jan 21, 2005 | 09:56 AM
  #19 (permalink)
Drewpw4ng's Avatar
stock :-\
so 80MM and 65 mm is the way to go?
Old Jan 21, 2005 | 09:59 AM
  #20 (permalink)
I said it would work fine - I didnt say it was the best price For that, go with sol_93gts suggestion - C&L Yes, 65 on the tb is good for quite a bit of HP.
Jeff
