Anyone know the HP rating for the FRPP 302 Sportsman block?
Old May 8, 2010 | 09:01 PM
  #31 (permalink)
GNs-r-slow's Avatar
Bondsman
Originally Posted by Stealth Mode
Huh
wut? Grout fool! also known as by the product line of Hardblock
Old May 8, 2010 | 09:07 PM
  #32 (permalink)
Stealth Mode's Avatar
Still CREEPIN
Oooooh,.. Gotcha. Lol
TurboRAM Member #5
24psi & Stable
GET SOME
Old May 9, 2010 | 03:52 PM
  #33 (permalink)
BigDawg's Avatar
has his prioritys ef'd up
So you think a girdle will help stabilize crank walk? I can show you dozens of pics with massive destruction of guys using girdles. There are pics on Stangnet, Corral and ModdedMustangs showing how effective a girdle really is. Its only effectiveness lies in the fact that it keeps all the peices from shooting through the oil pan and onto the track. Let me guess, your a believer in the valley girdle as well. And not trying to knock you off yoru horse champ, but your a machinist, Not an engine builder. I take my block and crank to you to cut or polish, not to put it together. Just like I wouldnt take my car to a muffler shop to get A/C repair work done.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old May 9, 2010 | 08:42 PM
  #34 (permalink)
GNs-r-slow's Avatar
Bondsman
You dont run a valley girdle? Shame on you!
As far as the statement about a machinist being an engine builder. If a performance machine shop arent engine builders ....you went to the wrong place!
Old Sep 29, 2013 | 08:23 PM
  #35 (permalink)
zoomersgarage's Avatar
Default Main Girdle
I have a moment here and just wanted to share what i've seen in the field with many main girdles. I've seen alot of bolts and studs come loose more than anything, due to differences in materials used, poor holding/clamp force/load and poor machine quality with all girdles. Remember when your tourqing down each main cap with a torque wrench; your getting a great holding/clamp force/load for each main cap your tightening; but with the main girdle, you loose this holding/clamp force/load; fastener stretch characteristics change, your gambling with the holding/clamp force/load; that you now have to transfer through the main girdle (weak link). What I mean is that you now have to torque down your main bolts/studs in sequence (like a cylinder head) from center-out and hope that you get enough/adequate holding/clamp force/load applied to your main caps. I've even seen aluminum main girdles which is scary to me. I believe a main girdle is a weak link in your foundation. Also be prepared to grind down the arrows and numbers on top of your main caps so the main girdle clears and hopefully sits flat on top of all your main caps.
Furthermore, if you wanted to put something on nice and more effective in my opinion, install a windage tray; these do not affect the holding/clamp force/load, because they usually install after you have tightened all of your main caps down; but beware, there is no such thing as a bolt-on windage tray without modifications; you'll need spacers to space them away from the crankshaft counterweights so they do not come in contact with the windage tray as they spin; you'll need to shorten or lengthen your oil pump pick-up tube for proper pick-up to bottom of oil pan clearance; and check that your dipstick tube does not hit; if it does you may need to drill a hole or remove material from the windage tray.
To conclude, I hope this info. was useful in your journey, my name is ryan from zoomer's performance and I specialize in building street small block ford strokers; my ebay name is zoomersgarage
