Carbs. Vs. Injection
Old Feb 4, 2004 | 10:30 AM
EsCoRtLvR's Avatar
Escort Connoisseur
Right, but EFI is better on the wallet than a carb will ever be It also can adapt to temperature adjustments etc unlike carbs. You might get a perfect A/F ratio one night and another night it could be a tad warmer and stickier and change your A/F ratio. Whereas EFI works much better by adjusting itself to the conditions given. Carbs make more power, but EFI is more adaptable Just my opinion. Good read though!
"Genuine" ASE certified Mazda, Hyundai, Isuzu Technician
Escort Enthusiast Site
Automotive Electrical Specialist, Tuning Specialist
Old Feb 4, 2004 | 11:00 AM
Alan's Avatar
drives euro trash
How so?
Carburator gives you total control of A/F with the turn of a few screws (more or less ). The cheapest way to get this kind of control on a EFI is the new Diablo or Superchip for about $300-400. The cost of using the tools out of your toolbox which you already have to tune a carb is much less than fiddling around with a computer. My .02
Hell, worse case senario is you have to purchase a standalone type pcm. That will cost you at least $1500, plus the cost of a laptop. Cost effective my ass.
Old Feb 4, 2004 | 12:12 PM
race495's Avatar
Pull Over
Originally posted by phatstang1
How so?
We are not talking stock stuff here, we are talking high end no holds barred.
Break down the cost of carb vs. efi on a forced inducted setup making 700 hp.
As far as the carb vs. efi argument, there are many variables to throw in and it is usually a draw on who is faster. Even on this article, did the TB flow the exact same as the carb setup? It doesn't mention that does it? Did they just run a spider type efi setup and replace it with a carb? I have yet to see a real, honest scientific test of either.
Other tests I have seen place the carb ahead on hp but losing on torque production. Again, these tests were not scientific and there were no flow comparisons done.
I say this as an efi and carb owner.
"I'm in the 82nd Airborne and this is as far as the bastards are going!"
93 Cobra, R302 331,canfields,T-76,TKO......sold
87 Coupe, 466, Edelbrock heads,Vic jr,150 shot 10.41@129.5...sold
2006 Honda 450ER .....new toy
Do you own a Torch Red FRC and tremble every time you drive under I75 on Hwy 60 and look in your rearview mirror? If so you are suffering from what is known as Cobraphobia.
Old Feb 4, 2004 | 12:59 PM
Alan's Avatar
drives euro trash
Okay...balls to the wall senario.
Scotts case: Can't make his case, forget how much he paid for his carb.
EFI case: if you truely want balls to the wall tunability, you'll need some sort of "standalone" pcm. Take Pectel for example. $2500-3000 for the ecu with wiring harness. Add anywhere from $100-1000 for a laptop. That hasn't even touched larger injectors yet.
All in all, I think you can make a case for both sides showing either way is more expensive. I think expense should just be left out of the equation.
Old Feb 4, 2004 | 03:52 PM
EsCoRtLvR's Avatar
Escort Connoisseur
I love how you guys ignore the adaptability commenting haha. That's what makes EFI that much better it can adapt to more than one condition by itself rather than have to go out and adjust the carb when it gets cooler/hotter out to get it right
Old Feb 4, 2004 | 06:09 PM
0HP930's Avatar
Guest
Its all about restriction of air flow and the proper mixing of fuel. A properly tuned FI system and carb that flow the same amount of air will make about the same amount of power with the edge going to FI. Carbs have no power advantage, but their difficulty to tune and sensitivity to pressure and temperature are critical problems that have led to the obsolecence of carburators. A high pressure sprayer can also better atomize fuel than a carb, so FI is also better at mixing fuel and air than a carb is too.
A lot of what I read above is BS, for example that a carb will better atomize fuel or that it will have a greater temp drop. The joule-thompson effect is just a fancy way of saying that if you expand a gas by lowering its pressure you also lower its temperature. To do so in an induction system you need a restriction. A carb needs the restriction to meter fuel, but FI does not. That temp drop does nothing good for the motor since this low pressure air will adsorb more heat than air that experiences less of a pressure drop before it reaches the cylinder.
So the bottom line is that the above text is nothing but a bunch of selective fancy talk trying to obscure the fact that carbs are inferior to FI from a guy who is trying to sell obsolete technology to auto enthusiasts.
For that reason I raise the flag for the above text as being both misleading and wrong on multiple points.
