Chassis & Suspension Tech Cages, braces, suspension set up and more
Post your suspension setup.
Old Mar 20, 2007 | 04:20 AM
  #41 (permalink)
nurve's Avatar
VQ35DE 6MT Sport
Omni-Power Full Coilovers (10k,12k)
Omni-Power LCA's
Benen Trunk Brace
Benen Rear Tow Hook
Spoon Upper F & R Tie bars
Spoon Rear Lower Tie Bar
Integra GSR Front Brake Conversion
Rota J-Mags on Nitto NT450's
Not much but I love the ride and the chassis stiffness!
Proven Power
StricKly MT
Old Mar 20, 2007 | 11:10 AM
  #42 (permalink)
terry.ho's Avatar
I love to choke people.
2002 RSX
Koni adjustable shocks
Neuspeed Race Springs
Neuspeed 27mm Front Swaybar
Neuspeed Front Swaybar bushings
Neuspeed 22mm Rear Swaybar w/subframe support
Neuspeed Upper front tiebar
Neuspeed Upper rear tiebar
Neuspeed Front lower x-brace
Ingall's Fast-Cam front and rear camber kits
This is all in my garage waiting for me to get the time to install it.
Originally Posted by fresh&clean
This is the worst place to get any advice at all.
http://www.myspace.com/terry_ho
Old Mar 20, 2007 | 11:41 AM
  #43 (permalink)
Chuck 98 RT/10's Avatar
Sexist
Chuck
www.BabelMotorsports.net
www.SAFEMotorsports.com
Old Mar 20, 2007 | 02:06 PM
  #44 (permalink)
terry.ho's Avatar
Originally Posted by Chuck 98 RT/10
You thought I was joking?
Old Mar 30, 2007 | 03:37 PM
  #45 (permalink)
Outkasted24's Avatar
** I ♥ Old Skool **
The Current '04.5 V-Dub Jetta GLI 1.8T
- Stock GLI 18" BBS RC's w/ Goodyear Eagle F1 225/40-ZR18 tires
- BBS Center caps from Tirerack.com
- H&R 8mm hubcentric wheel spacers w/ bolts in front
- H&R 15mm hubcentric wheel spacers w/ bolts in rear
- H&R Race springs
- Koni Yellow Adjustable shocks
- Neuspeed 25mm front lower swaybar
- Black Forest front Lower adjustable endlinks
- Neuspeed 28mm rear lower swaybar
- Neuspeed rear upper strut tower bar
- Neuspeed front upper tie bar
- Neuspeed front lower tie bar
- EM Racing C-Pillar Bar
The Current '04 Honda Accord Sedan
- 19" Axis Neo's with Nitto 555 235/35/19" tires
- Tein S-Tech springs
- (HFP) Honda Factory Performance Shocks
- Ingalls Adjustable rear Camber/Toe links
- Comptech 22mm Rear lower swaybar.
The Old '00 Honda Civic Si Coupe
-15” Rota Slipstreams w/ 205/50/15” Falcon zeix tires at 90% life left
-Sparco 4pt Harness Bar
-Skunk2 2nd gen. Upper A-arm camber kit
-Lakewood Titanium Traction Bars (never fully installed)
-Korbach Red Frame Locks
-Benen Black 3 point upper strut tower bar.
-Benen Black Rear Upper Tie Bar
-Benen Black Front & Rear lower Tow Hooks (+ 1 extra Rear)
-Benen Black Inner Trunk Strong Bar (Road Series) 4 bolt
-Benen Black rear Lower tie bar
-Benen Black Front Lower Tie Bar
-Benen Black 1st Gen. strong bar (custom fitted)
-Benen Black Front Lower X-Brace
-Silvers JDM Engine Damper (custom fitted)
-EM Racing/DRIVE Brake Master Cylinder Brace
-Beaks/JDM ITR 23mm rear lower tie bar kit w/ Suspension Tech. Polly D-bushings
-Tokico Illumina five-way adjustable shocks w/ Ground Control coilovers
-OmniPower rear LCAs
The Old '99 Acura Integra JRSCed Ls
-16x6.5 Bronze Rota Circuit 8s wrapped in 205/45/16 Yokohama Parada Spec-2s, 70% tread left on tires
-Neuspeed Race springs @ 2.5" drop
-KYB AGX. Adj. 4 way Shocks
-DC Sports rear lower polished tie bar
-DC Sports rear upper strut tower bar
-Neuspeed front lower tie bar.
-Neuspeed front upper 4 point strut tower bar
-JDM Do-Luck* polished back seat floor chassis bar
-Suspension Techniques 24mm front lower Sway bar w/ Poly. Energy Suspension Red Endlinks and D-bushings
-ITR 23mm rear lower sway bar
-ITR trunk rear deck frame bar
-DIY tubular 1" rear seat delete brace, custom made and installed.
-J's Racing Engine Damper
-J's Racing C-Pillar Bar
My Flickr
slam.poke.drop.tuck.dope
Old Apr 8, 2007 | 08:48 AM
  #46 (permalink)
aimmotorsports's Avatar
my '88 crx si is set up for drag raceing as:
front:
'92-'95 civic strut forks
kyb agx
ground control copies coil overs with 350 lbs/in springs
prothane bushings
and a prototype traction bar
rear:
'99 style kyb agx
ground control copy coil over with 450 lbs/in springs
meagan lca's
removed swaybar
prothane bushings
Old Apr 18, 2007 | 05:36 AM
  #47 (permalink)
MAYMAY's Avatar
nice red bull F-1
for my eg6 civic..
kyb shocks...tenzo springs..
not too low..ideal for daily drive...
front and rear upper strut bars..
Old Apr 18, 2007 | 03:43 PM
  #48 (permalink)
97dxcoupe's Avatar
tokico blues
tein s-techs
all 4
theyre not in the car yet since the car is in the shop
I © my Honda
i need
96-98 rear bumper (black)
96-98 fenders & hood (black)
rear filler panels (under tailights)
glove compartment lid/cover ( dark grey)
driver side ac vent(upper dash one)
TR "F#UCK Thieves" crew Member #10
Old Apr 18, 2007 | 04:38 PM
  #49 (permalink)
cosworth34677's Avatar
progessive springs
stock upper tower brace
custom upper rear frame brace
gt spec lower frome brace
gt spec msp swaybar links
awr poly bushings in the pillow ball mounts
h&r camber correction kit
one bad brotha!
Old Apr 21, 2007 | 03:09 AM
  #50 (permalink)
terry.ho's Avatar
2002 RSX
I got it all put in yesterday and the shop is setting the alignment on Monday.
