Chassis & Suspension Tech Cages, braces, suspension set up and more
Post your suspension setup.
Old Feb 24, 2007 | 09:48 AM
The Kyle's Avatar
Captain Catastrophe
Default Post your suspension setup.
Just wanted to drum up some good convo in the new forum
Car: 97 BMW 328is
Koni Adjustable Shocks
H&R Race Springs
Turner Motorsports 28mm Front Sway Bar
Turner Motorsports 22mm Rear Sway Bar
Turner Motorsports Rear Lower Control Arms
Turner Motorsports Trailing Arm Bushings
Turner Motorsports Trailing Arm Bushing Limiter Kit
Turner Motorsports Solid Subframe Bushings
Energy Suspension F&R Sway Bar Bushings
BMW Motorsport X Brace
Old Feb 24, 2007 | 09:56 AM
John's Avatar
lol @ tampa
Currently I have Tanabe Se7en coilovers, with the TEAS electronically adjustable ride, plus adjustable camber plates. Plan on adding a rear sway bar in the future, but the Evo doesn't really need much in the way of mods to suspension to make it sick.
2008 AW 335xi coupe - Dinan stage 2 - DCI - Dinan axle back
|Full color business cards||flyers||postcards||more|
Old Feb 24, 2007 | 10:10 AM
TunerElite's Avatar
The Right-Wing
kyb adjustables
eibach springs
energy bushings
dc front strut bar
dc rear lower and upper strut bars
Old Feb 24, 2007 | 10:55 AM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
tokico front and rear adjustable coilovers
I lose ...
soon to have:
subframe brace
rear lcas
passwordjdm front 3-point strut tower bar
rear strut tower bar
sway bars
-Winston Churchill
Old Feb 24, 2007 | 11:44 AM
Ronald Mcdonald's Avatar
Shakotan/Hippari life.
Tein S-tech springs
KYB shocks
Front and rear strut bars
Energy suspension front subframe bushings
On Monday, I'm getting Kei Office coilovers, I can't wait!
-'03 GSX-R 750
Old Feb 24, 2007 | 11:49 AM
HellofaPrzeFghtr's Avatar
The One and Only
My sil80 has-
K-sport coilovers
Megan F&R Upper strut tower bars
Adjustable Lower rear strut tower bar
Adjustable Rear Upper Camber arms
Adjustable Rear Traction arms
Adjustable Rear Toe Control arms
Adjustable Front Tension rod
Front Lower Arm Bar Under brace
Subframe Bushing collars
Energy Suspension Bushings all around
Old Feb 24, 2007 | 12:13 PM
B18C5-EG's Avatar
SUSPENSION
(consisting of)
TECHNO TOY TUNING coil overs with fully adjustable a.g.x's
rear T.R.D. springs
TECHNO TOY TUNING roll center adjusters
SILK ROAD adjustable liength controll arms, boxed w/sperical rod ends
FULL polly-eurathane bushing kit.
TECHNO TOY TUNING camber plates
JIC MAGIC strut tower brace
brand new MOOG inner and outer tie rods and ball joints.arround
BRAKES (cosisting of)
brembo rotors (new)
full 5 line GOODRIDGE stainless brake lines.
ceramatalic pads
A.T.E. super blue racing brake fluid imprted from germany
DRIVETRAIN
(consisting of)
FIDANZA lightweight flywheel
EXEDY stage 2 clutch
custon one peice driveshaft
GOODRIDGE stainless clutch line w/A.T.E. super blue inside
REAREND
(consisting of)
T.R.D 2 way l.s.d.
new carrier bearings
new axle bearings
new pinion bearings
crush sleeve replaced with custon aluminum sleeve for durability.
Old Feb 24, 2007 | 01:06 PM
lowryder420p3's Avatar
i only have tokico shocks all around and racingbeat lowerin springs about 5 days old. lol not much for suspension but its all good
also fresh brake system.. cross drilled brembo rotors, oem mazda pads, brand new calipers and all new brake hardwear.
Old Feb 24, 2007 | 01:21 PM
japanbran's Avatar
Bo0st FTMFW
2001 integra
koni yellow adjustable shocks(F+R)
sway bars(F+R)
lakewood Ti Traction bars
benen front lower sturt bar
skunk 2 front uper strut bar
skunk 2 rear upper strut bar
F+R camber kit
Rear megan racing LCAs
poly bushings
skunk 2 coilovers F+R
powerslot rotorsF+R
hawk padsF+R
ss. brake lines
phearable.net
R.I.P DJSTANG. YOU WILL NOT BE FORGOTTEN!!!!
Old Feb 24, 2007 | 01:48 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
Originally Posted by B18C5-EG
SUSPENSION
(consisting of)
rear T.R.D. springs
brembo rotors (new)
ceramatalic pads
DRIVETRAIN
(consisting of)
REAREND
(consisting of)
T.R.D 2 way l.s.d.
new axle bearings
new pinion bearings
damn you!!!!
im all stock
