Headshake at 60mph?
Old Jul 31, 2007 | 09:35 AM
TNathe's Avatar
easily fixed, down shift into 2nd and clutch it up then ride out to the desired speed and hold. no tire on ground no problem right?
Does it get worse if he goes faster or does it go away. if it has certain speeds its prevailant at its most likely the tire and chances are you may not SEE anything wrong it.
Old Jul 31, 2007 | 09:49 AM
Cecil's Avatar
gone fishin
best answer yet
Old Jul 31, 2007 | 10:49 AM
Wicked1's Avatar
I'm serial guys, a worn-out front tire usually causes that. Replace front tire = good to go.
Old Jul 31, 2007 | 12:14 PM
Frankie Figs's Avatar
Too Much is ALMOST Enough
Its dropped and stretched
It does get worse from 40-60mph. He doesnt want to take it any faster than that.
You mean serious or are you a serial killer??
Old Jul 31, 2007 | 12:28 PM
TNathe's Avatar
40-60 is a WIDE range for this effect. Like my car does it right at 60-65mph holding a steady speed. The tires arent exactly round on my car anymore. Any less than 40 and ur prob not going fast enough to cause the vibration. Is it 'vibrating' or actually 'wobbling'? I *think* theres a difference. If you guys check the steering stem torque like mentioned then the next thing i would do is remove the front wheel and take it down to a shop to have them put it on a balancer and spin it up.
Old Jul 31, 2007 | 12:36 PM
At 40 it doesnt really do anything, kind of a lil shake but at 60 it gets violent. So about 50-60 is where theres a major problem.
Old Jul 31, 2007 | 06:10 PM
  #17 (permalink)
Wicked1's Avatar
I'm serial guys...it's a South Park reference...Al Gore and the Man-Bear-Pig episode.
