injector ?'s
Old Dec 12, 2012 | 12:49 PM
Pennywise's Avatar
why so serious????
Default injector ?'s
i have a 98 jetta. its a 2.0 with an aftermarket kit on it, running a T3/T4 turbo. wondering what size injectors i need to run 25psi. not sure what size is in it now. when i bought it i was told that injectors where the only thing left to do to get to 25psi of boost
Cornbread Crew member #754
Old Dec 12, 2012 | 01:38 PM
G-Magoo's Avatar
July - Ride of the Month
Injector sizing is not dependent on boost pressure so much as its dependent on the amount of power you're trying to make. Do you have a hp level in mind?
I love haters..
Originally Posted by VR6exxy
I love your brutal honesty. It makes my day
Build thread
Old Dec 27, 2012 | 07:10 AM
Pennywise's Avatar
why so serious????
sry for the slow response time been really busy during the holidays. well im not sure about the power, i guess the best thing to do now is get it dyno'd to see where its at now at 10 lbs. it seems that when i tryed to push more boost than 10lbs it would break up really bad, but i believe that was because of a damaged ingnition coil wire( i removed it yesterday when just checking things and the end of it just disintegrated). thank you for the response tho, this is my first VW and im just tryin to learn the ins and outs of the car.
Old Jan 7, 2013 | 01:51 PM
G-Magoo's Avatar
Yeah its hard to be able to suggest an injector size based strictly off boost. Lets put it this way, if you want say 250whp from the 2.0, Id suggest an injector around the 42lb/440cc range.
Here's an injector calculator if you want to play with the numbers...
Fuel Injector Calculator from WitchHunter Performance
I love haters..
Build thread
Old Jan 7, 2013 | 09:32 PM
Green_Lantern's Avatar
Green Lantern Corps
I would be curious as to what software you are running... Also what other modifications do you have besides the turbo. Shoot 25psi is lot if you don't have supporting mods...
If you're not cracking oil pans your not low
Tampabaytunedinc
For Sale/WTB Subaru
4
Aug 3, 2012 07:33 AM
deez92
Jan 20, 2005 12:28 AM
vetkilr
Dec 12, 2002 08:18 PM
foesicks
Apr 16, 2002 10:08 AM
