nothing on in the supra
nothing turns on nothing i even have a fuse tester all the fuses are fine and the wires from the terminals are fine and i checked everything all the wires are good could it be my alternator
Also could be the ignition switch is bad, if you are electrically inclined try running a 12volt hotwire (with a inline fuse on the wire to match the main fuses rating, I think it is 40, 60,80 amp fuse) from your battery to bypass the ignition switch, if you get power to everything, I would say its the ignition switch then. Only do this for a few seconds, do not try to start the car up like this, this is not a fix, just a way to troubleshoot.
either bad battery or bad ignition siwtch.
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
MK3 TSRM On-Line
that switch.
