nothing on in the supra
Old Jun 3, 2009 | 03:10 PM
LexusKrazzyBoy's Avatar
Default nothing turns on in the supra
well today i get home and the car wont start i look at every thing and battery is old and dead. i go and buy a new one and wen i put it in the lights turn on and everything is good but wen i go to start it everythin dies so i go back out side take the battery out then i put it back in and everything turns on i go to crank it and it dies again but now for good theres no power to anything i tried everything nothin works please help oh and its an 89 turbo
Old Jun 4, 2009 | 07:55 AM
Boosterseat's Avatar
No Rice Here
Did you clean up the terminals? Check the wires to see if they are corroded.
Old Jun 4, 2009 | 01:00 PM
boricua114's Avatar
clean terminals, if not take the alternator to advance auto parts or auto zone for them to test it
Old Jun 4, 2009 | 02:08 PM
williamb82's Avatar
grease monkey!
sounds like bad connections. and where did you get this "new" battery? if its a recycled one from square deal or somthing its prolly just bad.
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
Old Jun 4, 2009 | 02:10 PM
isuzudubs's Avatar
check the battery fuse
Old Jun 4, 2009 | 08:51 PM
one of the battery terminals are broken will get new one tomorrow battery is brand new from advanced auto and could it be the alternator it started fine a few days ago
Old Jun 5, 2009 | 09:10 AM
williamb82's Avatar
grease monkey!
if the battery terminal is broken that would explain it. only way for EVERYTHING to die is if the battery is dead or disconnected. there is no 1 fuse that will kill everything.
Old Jun 5, 2009 | 06:16 PM
well i hope thats it
Old Jun 9, 2009 | 04:20 PM
changed the terminals still nothing wat can it be
Old Jun 10, 2009 | 05:49 AM
No Rice Here
Is the car totally dead? i.e. nothing works, no lights, no radio, no nothing.
Check the wires that goes from the battery to the fuses, then check the engine bay fuses themselves, then check the wiring leaving the fuse area. Other than that, all I can say is the battery is defective, and wont hold the charge.
