Wife's Matrix, check engine light and a/c??
Old Feb 18, 2008 | 05:23 AM
J-Dizzle's Avatar
Still Addicted to Boost
Originally Posted by 82RollaSR5
What are you talking about all those cars are built on the Toyota Corolla platform. Using the Corollas engine, trans, interior i mean everything except some of the sheet metal. Not just that but the Matrix is only built in Canada while the Vibe and Corolla(not all) are built a NUMMI which is a Toyota and GM joint venture plant which also produces the Tacoma. The Vibe isnt a POS either its just a cheaper less equipped Matrix. They are all the same CAR. And i dont see anyone saying Corollas are POS's.
Also there are several reasons your ac could blow not cold. Relay could be bad(is the light blinking). You could have had a rock hit your condensor and put a whole in it(seen it a few times). As for the check engine light there are over 200 different things that can turn that light on from a loose gas cap to a pin hole leak in an EVAP line to a bad transmission. All in all just take the car to a Toyota dealer. They will fix it.
my bad,i always thought it was Gm that supplied the motors and such.
Old Mar 2, 2008 | 08:48 AM
KAILUAZ's Avatar
Infidel
Originally Posted by hombredelassrtas
nice, i hear about this randomly, its an odd thing to cause all those issues. Let me know if you need a code read next time so you dont have to spend money at autozone (unless it was free)
Thanks for the offer, it was free though. Now I just have to figure out the A/C issue.
Old Mar 3, 2008 | 06:06 PM
KAILUAZ's Avatar
Infidel
Ok, so here is the deal on the A/C. The compressor wont come on when I hit the A/C button. The engine will idle up, but the pulley just keeps spinning and the compressor clutch won't engage. I checked the fuse panel but couldn't find the A/C fuse or breaker. Anyone know where it is? I think that is the problem.
Thanks!
Old Mar 6, 2008 | 02:38 AM
whiteknight's Avatar
the knights will ride!!!!
Kailuaz, go in to your fuse box under the hood and pull out your AC. Magnetic Clutch relay, replace it with you horn relay. if the relay is the problem then you will know right off the bat as soon as you start the car again. i work for a toyota dealership and thats the first trouble shooting step we do for the that type of problem. they all end up doing it, keep us posted.
Old Mar 6, 2008 | 05:06 PM
Silverkill's Avatar
Whiteknight is right. TSB on that.
Old Mar 10, 2008 | 10:42 AM
F4A22's Avatar
Old School
+1.We stock like 10 at the dealership i work at pm me if you want a price.
Old Mar 14, 2008 | 05:54 AM
  #17 (permalink)
KAILUAZ's Avatar
Infidel
Sorry I haven't checked back here, thanks for the info.
After looking under the hood I couldn't find anything labeled "A/C" on the fuse panel. I crawled under the dash and saw the "A/C" label, but there is now way I can fit further under there to see where that relay is located.
Anyone have a picture of where the A/C relay is located?
Thanks guys!!
Old Mar 16, 2008 | 12:43 PM
  #18 (permalink)
KAILUAZ's Avatar
Infidel
Anyone?
Old Mar 16, 2008 | 01:09 PM
  #19 (permalink)
rodknock_racing's Avatar
TRD_hmong_racer
its located under the hood....fuse and relay box....its called "Magnetic Clutch relay" or "m/c relay".......swap m/c relay with the horn relay and turn on the a/c......if it works.....go to a toyota dealership and buy that relay.......lmk what happen....STY
Old Mar 16, 2008 | 07:19 PM
  #20 (permalink)
KAILUAZ's Avatar
Infidel
Thumbs up
SWEET, that was it! Thanks so much for the help, this place is great!!
