1jz into 85 toy pick up
Old Jul 9, 2007 | 06:28 PM
92hatchGSR's Avatar
sohc sshhhhh
Default 1jz into 85 toy pick up
has anyone on here tried to put a 1jz into a pick up . if so how hard is it and what do i have to do? thanks in advance
Old Jul 9, 2007 | 06:39 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
think i saw that once.
you need the all essential basics that you would need for swapping any engine into a chassis that it was never intended to be in.
the 85 was 22re depending on the model, its more than likely carbed. if thats the case your in for one big headache.
i would say that you could fit the 1J's tranny in there without bashing are really cutting into anything (maybe the shifter well, the 1J tranny might be longer) you would probably need a custom driveshaft.
the mounts would probably have to be fabbed also. i doubt they have the mounting setup as the 1J.
Old Jul 11, 2007 | 12:33 PM
RTA Supra's Avatar
RIP Kevin
There's been quite a few to do it. There's a guy named Matt that works at Toyota with a 7M in his truck. Another guy that worked with him named Ryan had a 7M, then 1J in his.
Looking for OEM Acura parts? PM me
GO BOLTS!
09 Civic Si
Old Jul 11, 2007 | 05:20 PM
92hatchGSR's Avatar
sohc sshhhhh
^i think i have seen them around are both of the trucks white
Old Jul 11, 2007 | 05:21 PM
RTA Supra's Avatar
RIP Kevin
yup. Ryan doesn't have his anymore though
GO BOLTS!
09 Civic Si
Old Jul 11, 2007 | 05:30 PM
oASHo's Avatar
Lace Up!!!
i feel that it would probably be the same swap if not easier then the mk2 or any other non ordinary swap, if im correct the engine bay is a little bit bigger than the mk2 which should fit the 1jz in quite nice, just like any other swap, your going to have to redo all your wiring to support the 1jz and make custom mounts. after everything is mounted your going to want to put a 1piece or 2 driveshaft in , and swap rear ends, depending on how much power your wanting to put into this truck. hope this helps and good luck.
Old Jul 11, 2007 | 06:26 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
1uz turbo you wont!
YOTA ROBERT's Avatar
there used to be a guy at xat that did this swap and i mean this bitch was nasty as hell
Old Jul 11, 2007 | 07:13 PM
oASHo's Avatar
Lace Up!!!
hah jordan thats weeak sauce. 1gz v-12 ftmfw.
Old Jul 12, 2007 | 04:56 AM
RTA Supra's Avatar
RIP Kevin
That would be Ryan
GO BOLTS!
09 Civic Si
