Tercels!!!
Many times it is, but not always. There are many different ways to vary cam/valve timing that are used.
As far as the HG...just fine, as I have an HKS MHG torqued right. I've never had a HG problem with my Supras.
For the record, all 7Ms were improperly torqued from the factory, because the original 56 ft lb spec was for asbestos HGs instead of the material they used instead. Thats the only problem; the HGs arent weak or troublesome. Anyone who says otherwise hasnt done research or had experience. Frankly, the fact that they last 100-150k miles on average should be commended I think..holding up so well to a HG torqued wrong. I'd like to see that same problem happen with other cars.
The GM pushrod 3.8 (which is an excellent engine) for example would blow HGs on the turbo ones originally, though it was because the engine wasnt built for boost properlly...neither was the 7M, which has been pretty damn similar since the original M way back when and the 3M in the 2000GT
I could fire back with a torque comment on the 1JZ, but I know they arent torqueless after having a ride myself; the comment people make about the 1JZ's lack of torque is just as legitimate as the 7M's crappy HG's; which is to say not at all
ASE: Brakes
ASE: Brakes
lack of torque(if any, i mean i do drive hondas) is easily overcome by 4.30 gears and a small(er) turbo. As for tercels, I would like to have a one just so people would leave me alone and not want to steal me car.
WTF!!
you fuking moron you guys the one who put you stupit model vs honda not me!! fuking idiot read the post
all i did is you ? and i answer and that set..
here for you all stock so bocon
celica vs - Google Video explain what happen here
250hp vs 185hp huuu
I miss tampa fl
I miss tampa fl
Go back to school, learn to talk, then learn to type, and then try saying that again.
And dont pull that "i jus type liek dis" bullshit, take the 2.4 extra seconds it takes to PROOFREAD your bullshit so it makes sence.
ASE: Brakes
ASE: Brakes
so bocon..
I miss tampa fl
I miss tampa fl
Again, I implore you to READ what you TYPE before clicking submit post.
Oh shit..."implore" means suggest..perhaps I shouldnt use big words around you to make your TR experience easier?
ASE: Brakes
ASE: Brakes
yeah, i cant believe i created this monster,
