1jz vs 7mgte
Originally Posted by supratruck
C: the engine will also be lighter...
D: you will also make more power with the "factory" turbo's...
E: You can find complete 1j front clips that will be in your budjet..
F: If you go 1j it should be low mileage...not to knock down the 7m, but it may have higher mileage and already have had several head gasket jobs on it, which is fixable but the blocks do get pitted over time unfortunately.
I swung on 1JZs nuts for a whole year, so I used to know stuff about them. Now I think the 7M is the perfect engine
Oh, and HachiBill is right, technically cars with similarly built characteristics are capable of 7k+ I have only heard, though the 86.5-early 89s will be your best bet for revving. The differences are very little between the two...the pre89 7M is closer to a 6M than a "7M" really in some ways, which still isnt different. Dont make it a make-or-break subject based off of year/crank
ASE: Brakes
ASE: Brakes
do not know the exact weight of each engine, but when installing in a vehicle such as in a truck that used to have a 7m in it, the truck sat about 2"s taller, that should give some idea...i personally know 3 different people that have purchased complete "engine,harness,turbos,ecu,ect..." one was a front clip complete...shipped for well under 2k
I had the same question with my car and I am sticking with the 1j in my car. I am in it for direct drop in though. I wanted something with good daily drivability and a good power band. I also saw one person say the 1j was cheap and one say it is expensive. It is true that the 1j is getting harder to find at importers but also there are more out there being sold and sold back as a result of poor money management and failed budget requirements in the suspect build up. THis gets you a lot of people who thought they had the time and money selling the clip (or motor) back at a lot lower cost. Don't let shipping scare you. You will be able to ship the clip for under 500 from anywhere in the contiental us and th emotor for even less. My count from NY to FL was 350 and I got a better deal then that in the end. I just got my jzx81 clip for 1500 + shipping so look around and you will find the right deal. Anyways if you want a 7m-gte motor I have a spare one for you : ) The aftermarket parts for the 7m over the 1j is another plus, Front facing intake manifolds are available which to me definetly dresses the 7m up. Check supramania supraforums and other supra resources to get the skinny on the motors. We can only tell you from personal preference and your assumed needs. It is you who knows exactly what you want and you need to get that from both our input and your own research
PS don't the NA cams only increase power in pre 89 motors. And the 6m crank can't hold massive amounts of power as it is known they break around the 600 mark ,but that is more then you want, the reving will be an issue but a head job is right around the corner.
N/A cams increase 10 HP throught the powerband...the turbo MkIII cams never changed in the years. The cams have less lift and more duration, which is good for lower end probably. And finally the only cam that is different is the intake cam IIRC, all exhaust cams are identicle
ASE: Brakes
ASE: Brakes
