MK3 tail light problem
Old Dec 12, 2005 | 06:41 PM
BPU95's Avatar
the base production unit
Default MK3 tail light problem
i just got my new motor put in and in less than 500 miles later the tail lights do not work. they turn on when my brake is applied but not when i have the headlights on. all other lights/markers work, all the bulbs are brand new and i checked the fuses. nothing seems out of the ordinary. there is a box wired into the left rear light i am guessing is what controls the you've got a burnt out bulb in the gague cluster. this has happened in my formula as well and and has not been fixed yet either. any suggestions on what is causing the problem and how to fix this?
Old Dec 14, 2005 | 06:49 AM
BPU95's Avatar
nevermind, the problem seems to be a short in the little box i was talking about
Old Dec 14, 2005 | 05:16 PM
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
Really? I'll have to examine that as I have the same problem...no tailights, no backups either, but brake lights work. The "no back up lights" is just because the previous owner never reconnected the backups when swapping over to manual though
ASE: Brakes
Old Dec 14, 2005 | 06:23 PM
BPU95's Avatar
yea it is an expensive "dealer" part. i went to the junkyard and found one intact and swapped the circuit board inside. mine had a hole burnt in it but some i was told are fortunate enough to just melt the solder off the connections which are repairable
