1jz vs 7mgte
Originally Posted by supratruck
I was talking about how tall the engine is. Hints the word "TALL" not how long the engine is, as in "LENGTH"
For example: I found a toyota 1jz-gte is not as tall as a 7m-gte, in exception to IDEALSUPRA's 7m-gte due to a cylinder head torqued to 9,000 ftlbs.
thats fucking sweet, I cant wait to start this project nice pics. By the way supra truck is your truck white and was it running at the tr event if so you have a badass truck bro 2 thumbs to you man.
Airborne Infantry
Airborne Infantry
I want to go with a 1jz but it seems like I can get 7m alot easier, I seen one in the juk yard and thought about doing a stock rebuild with all arp hardware how do the stock pistons and rods hold up at around 400 on race gas 300 on pump thats where my goals are set at. 300-350 on pump also what kind of turbo should I be looking at? I appreciate all the help guys
Airborne Infantry
Airborne Infantry
7M ALL THE WAY,ESPECIALLY IF YOUR GOING TO put it in a older Z car!!! as loing as the motors fresh and in good shape, just to a 60-1 ct26, 680's, megasquirt, n/a cams, 1j style intake mainfold and your over 400hp at the wheels!! with soo much tq you could sell some of it to a 1j owner!!!! ahahahahahahhaahahahah
Boy oh boy. Where is all the 1j love. Sometimes it does suck to find replacement parts because not EVERYTHING is interchangeable with the 2j.
I think the 7m suites the z better and would be more within your budge.
Now post pictures
Now post pictures
Heavy car with a 2.5L
how high can you rev a 7m with the right supporting mods Iam most likely going to go with a 300zx turbo brakes all the way around. I love these older 240s they are so compatible with newer model nissans.
Airborne Infantry
Airborne Infantry
if you start ou with a 86-early 89 block you can rev it to 7k all day. the late 89 and after blocks had a different crank with bigger couner weights that you can't rev as high as the earlier blocks. the 7m's up until 89 were actually 6m botom ends, but after the changeover they started using the 7m botom end.
