A little birdie.....
more class than college
on
....Told me that peeps are stupid and talking about boosting a stock 1jz turbo set past 14.7(aka 1bar)
lets see.......
stock fuel cut....1 bar
stock ceramic turbo blade good for........1bar
360whp'ish..........1bar
Blown inline 6 due to greed and stupidity(and listining to TR members not me)...............priceless(aka me LMAS then crying)
fuel cut is there for a reason folks, 380cc injectors(or even the 440s) will not support much more than that. why push the limit on a motor like that.
seriousy if i hear of anyone fucking up a 1JZ i will come to see you, and the cheat will be there too.
lets see.......
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
i would assume the ct12's from the MKIV and the pump and injectors would also be a good idea, doesnt the block handle more than that?
95 Supra Turbo 6 speed
11 SWP STI sedan
11 SWP STI sedan
So was I wrong?
Anyways, its not that easy to just 'bolt on' the CT-12B's. Block can handle a shitload, but not quite as much as a 2JZ. Stock MHG needs replacing at ~ 25psi
http://www.supraforums.com/forum/sho...mk4+turbos+1jz
ASE: Brakes
ASE: Brakes
ANDY, MARK OR CARLOS
I need an ignitor ASAP.
If you have one please CALL 727-744-5788 Even just to swap it out for 2 mintues to see if thats the problem.
And kiddo why are you still talking about the same shit. Learn to drop stuff. you were wrong accept it.
Andy, i did get a boost spike to maybe 15psi. Chris and I are both very knowledgable on how crappy these turbos are and know why more cfm would need fuel.
Heavy car with a 2.5L
on
i know you know.
Originally posted by SupraKid
uh oh who messed up their motor?
Yes, you are right jeff. I didn't even pay attention to that
all in theory 440cc's should have no problem with 400hp. 440hp should be defiantly attainable at 100% duty cycle. Too bad the 1j has sucky turbos
