mmmmmmmm
Old Aug 13, 2003 | 10:51 AM
kbprice's Avatar
Rocket Scientist
Originally posted by flubyux2
id actually do the USDM 2JZ-GTE w/ a 1JZ head swap.
I just want to know where i can find a SC300 w/ a stick!
I'm curious as to why use a 1JZ head instead of keeping the 2JZ head?
FYI someone was selling a 93 5 speed on here a while ago. Wanted like $9K if I remember.
'96 Supra NA-T
"I'm not driving fast, I'm flying low..."
Old Aug 13, 2003 | 11:57 AM
agentAndy's Avatar
more class than college
the 1jz head is designed by YAMAHA. it flows better and the power delivery is much smoother than a 2jz. this setup is known as the 1.5jz. its still a soarer lhd or not.(imo) the five speed soarer is rare. just swap the auto for mani when you swap the motors. back to the 1.5jz, the .5 liters gained is not all that much of a benifit, but the fact is the 2jz internals are 6-700hp capable box stock. the 1jz is around 5-600hp ready. personally i would spend the 2500dollars (for the short block) on upgrading the stock turbos. the stockers turbine blades are only good for 14-16pounds befor they shatter. the compressor wheels are a little small too. ADI on i-supra has the stockers upgraded with kkk compressor wheels and steel turbine wheels. the housings have beens enlarged also. they are now capable of about 600hp. the this is my route. the stock fuel system on the 1jz is good for 400hp so that would not be an issue for a while. 1js rule you.
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
Old Aug 13, 2003 | 12:06 PM
J-Dizzle's Avatar
Still Addicted to Boost
guaauhahahauhaahauh
Don't Text And Drive
Old Aug 13, 2003 | 01:00 PM
kbprice's Avatar
Rocket Scientist
Thank you, that was very enlightening.
As for the end comment...
'96 Supra NA-T
Old Aug 13, 2003 | 11:19 PM
agentAndy's Avatar
this is what happens when the 1jz spools. hahahaha.
also with the shorter stroke of the 1jz the piston speed @6500rpm is the same as the 2jz piston speed@7500redline.
this is wht the 1jz is better than a 2jz and 1.5jz. the shorter stroke allows the 1j to rev harder and higher. lighter rotating assembly is a cause also. lets say you jump in a camero or any performace v8 and floor it to redine. pretty slow rev huh.
now jump in a gsr or any small displacement motor and do the same. revs faster and harder. just like f1 and superbikes. samll stroke=fast rev. the quicker you can get into the powerband and reach max boost and hp the faster you will go
sure there is a replacement for displacment.
its called boost.
Old Aug 13, 2003 | 11:20 PM
agentAndy's Avatar
the short stroke is why i also want a 1g-gte. 2.0 l-6.
so nice.
Old Aug 14, 2003 | 07:19 AM
  #17 (permalink)
TurboJZA70's Avatar
Old School "Turbo" dude
are you sure the 2j head is not designed by yahama?
Buy a TR email address Here
Old Aug 14, 2003 | 09:42 AM
  #18 (permalink)
agentAndy's Avatar
find a 2j and look at the front of the timing belt cover. does it say yamaha? i know the 1j does. yamaha is the best.
Old Aug 14, 2003 | 11:51 AM
  #19 (permalink)
Slash's Avatar
THE HAMMER
kinda a wierd offshoot but isnt the only taurus not to suck completely (the SHO) the recipient of a yamaha motor?
I dont feel like a sig today.
Old Aug 14, 2003 | 01:45 PM
  #20 (permalink)
MR2 Moogie's Avatar
YUM
- 1991 MR2 Turbo
